Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Like Tree12Likes
    CovX's Avatar
    Posts
    Default Galaxy Nexus 4.0.4 root help
    I unlocked my Gnex on stock 4.0.2 then updated to 4.0.4 with cwr. When ever i try to root it using wugs tool or gnexroot kit it doesn't work.But juice defender says i have root. How can i root it?
  2. #2
    silverdog's Avatar
    Posts
    Global Posts
    27 Global Posts
    Default Re: Galaxy Nexus 4.0.4 root help
    i finally got mine rooted/unlocked but cant get the rom to show up. i even wiped my phone clean. i was mad as hell. then i heard about the update supposedly coming out today ota.
    CovX's Avatar
    Posts
    Default
    On 4.0.4?
  4. #4
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by CovX View Post
    On 4.0.4?
    You need to flash the updated SU.zip found in the 4.0.4 update thread (in the general forum). That should do it.
  5. #5
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    If you have root on your 4.0.4 ROM then just download superuser from the market. If you don't, then flash this in CWR:
    ONLY FOR STOCK 4.0.4
    @silverdog... when you unlocked everything got wiped, including your sd, so you need to stick whatever ROM you are trying to flash back on it.
    Nobody should be waiting for a useless OTA. Flash a 4.0.4 ROM, and not a boring stock one, go with AOKP and just enjoy all the options you get with it. You have nothing to lose.. you can always go back to stock in just a few minutes with this phone, but believe me you will not want to.
    Thanked by 5:
    CovX's Avatar
    Posts
    Default
    I'll try that now
    CovX's Avatar
    Posts
    Default
    Thanks guys it workes
    dmmarck likes this.
  8. #8
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Excellent, enjoy!
  9. #9
    Default
    Here is the correct su:
    And you'll need root explorer to delete a script that over writes cwm with the stock recovery every time your phone reboots
    Thanked by:
  10. #10
    Default
    stock rom has an automatic "feature" that will reapply the stock recovery on reboot, overwriting CWM, etc.
    You can delete or rename the file "recovery-from-boot.p" from /system folder to stop it doing this
    Thanked by:
  11. #11
    chubb's Avatar
    Posts
    ROM
    Stock Xoom, Nexus 4 AOKP
    Default
    Quote Originally Posted by 2defmouze View Post
    Thanks. Everything else I've tried never worked. Good work.
    dmmarck likes this.
  12. #12
    Help! I am new to this whole experience: Verizon Galaxy Nexus. I have unlocked the Bootloader, flashed the CWMR 5.5.0.4 beta 6 recovery. I cannot get the su.zip or any zip file to show up. I adb push them to the phone, it seems successful, then I go to the recovery "install zip from sdcard" and it says "no files found" . Yikes. Now my phone is useless.
    I would appreciate anyones help. BTW I am using a mac.
    Thanks,
    newandroidguy
  13. #13
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by newguyandroid View Post
    Thanks,
    newandroidguy
    use the mtp connection with your computer to put the su.zip (use this one )
    so place that file on your sd card somewhere, like download folder or wherever.
    then, boot into recovery mode (you can do so manually by powering off, then powering up while holding Vol up, Vol Down, and Power all together) - then use volume keys to navigate to Recovery, then power key to select recovery. Then go thru recovery, install zip from sd card, find the su-latest and install.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  14. #14
    I was rooted on my Verizon GNex under 4.0.2. Got the OTA update to 4.0.4, but apparently have lost root (naturally ).
    When I go into FastBoot mode, it displays "LOCK STATE – UNLOCKED," but won't read the phone when I connect via USB to my Mac. I have downloaded the latest su.zip, but I can't reboot into recovery (nor can I do anything else a truly rooted phone can do).
    Tried to rename/delete the "recovery-from-boot.p" file using Root Explorer, but it keeps telling me the file is untouchable because it's a system file.
    Have run out of ideas; anyone have any other suggestions? (Obviously, it's past time for me to put a custom 4.0.4 ROM on the phone, but I need to root, first.)
    Thanks in advance!
  15. #15
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Quote Originally Posted by Steve Hall View Post
    Thanks in advance!
    are you at all familiar with fastboot?
    i would have you download the 404 su .zip straight from your phone (so it will be in your sd/downloads folder).
    then download the latest version of clockwork mod and place it in the same folder as fastboot on your computer.
    then you can put usb debugging mode on the phone while connected by usb to cpu, open up terminal or command prompt (depending if you use mac or pc), and "cd" to the folder that contains fastboot.exe (as well as the zipped up copy of cwm you will download), then you can enter this command:
    Code:
    ./fastboot boot recovery whatevertheclockworkfileiscalled.zip
    then you should have cwm temp booting on your device - navigate to install zip from sd card, go to downloads, and flash the latest su.
    after that reboot, flash cwm permanently whichever way you prefer (rom manager, fastboot) and you'll be good to go.
    any questions feel free to ask here
    gl
    Thanked by:
    Steve Hall likes this.
  16. #16
    Quote Originally Posted by zero neck View Post
    Code:
    gl
    Doh . . . I meant, I was unlocked under 4.0.2, not rooted. So yes, familiar with FastBoot. (And no, I can't reboot into recovery from FastBoot—I see the "LOCK STATE—UNLOCKED" notice, but it pretty much acts as though it's locked.)
    I'll try your suggestions—thanks a ton!
    zero neck likes this.
  17. #17
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Word I meant boot loader mode on phone and fast boot via CPU using commands.
    Let me know if that works out or if you need clarifications.
    Thanked by:
  18. #18
    Okay . . . phone is in Fastboot (bootloader) mode, lock state = unlocked (according to the phone). However, I can't find JUST Clockwordmod Recovery (zip file) to put in the same directory on my Mac as Fastboot is, to run the recovery.
    (Also, I'm away from home, so stuck with my Macbook Air, which never seems to see the phone in Finder, although other apps see it connected as a media device or camera.)
    I'll fiddle with it a bit more, but it's probably going to have to wait until I get home late this week.
    Thanks again for stepping up!
  19. #19
    Irvgotti's Avatar
    Posts
    ROM
    Stock Sense 4.1.1
    Thanks in advance!
    On you mac Do you have Android File Transfer downloaded? thats what i had to download for it to reconize my phone
    Privacy is overrated :P
    Thanked by 2:
    dmmarck likes this.
  20. #20
    Thumbs up Re: Galaxy Nexus 4.0.4 root help
    Quote Originally Posted by Irvgotti View Post
    HAH! On my iMac, yes . . . not on the laptop. Doh! (again). Thanks for the reminder
  21. #21
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    you need this:
    that's cwm touch - place that file in the same folder as fastboot.exe on your computer. for example, if you downloaded the superboot folder and left it on the desktop - inside that folder (mysid or whatever it's called when you downloaded the files to unlock/use adb/fastboot etc) - so inside that folder is adb and fastboot files (theyre executables but on a mac they will just say adb or fastboot).
    so, download the recovery file to the cpu and leave it untouched (still zipped), and place it inside that folder that contains fastboot.
    so you already have the latest su package in a zip on your phone after you download it from your phone browser - so you make sure usb debugging is checked, then you connect your phone to the cpu with usb.
    next, power off phone and power back on with vol up, vol down, and power held together to get to bootloader mode.
    next, open terminal on the cpu and cd to the folder that contains fastboot.
    for example, that folder is called "adb-fastboot" (i dont know what you're folders are called you have to enter the name of the folder, thisis just an example) - and that folder "adb-fastboot" is on the desktop.
    cd desktop
    cd adb-fastboot
    ./fastboot boot recovery clockworkwhatever5.5.0.whatever.zip
    that should get you into recovery temporarily, then you flash the su zip on the phone thru recovery, then you reboot system now, unplug the phone when it starts back up (not in fastboot mode! regular mode) - and from there you should be able to download rom manager and just flash cwm the easy way.
    good luck!!!
    Thanked by:
  22. #22
    *sigh* Not working. The download is an image, so I made a zip of it as well.
    Used the following command, and one without .zip:
    Code:
     /Users/sbhall52/GNexRoot/fastboot boot recovery recovery-clockwork-touch-5.8.0.2-toro.img.zip
    For both, I got this:
    Code:
    cannot load 'recovery'
    I think I'm going to have to wipe the phone and start over—seems that having the phone saying it's unlocked, but not really being unlocked, is playing hell with everything else.
    Appreciate all the help—I love how the people here go the extra mile to give anyone that extra bit of knowledge!
    I'll fight with this again when I'm not on vacation, and can give my full attention.
  23. #23
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Wait my bad. You want the img
    Leave it as an image: just cwm, su is a zip
    Just do everything I said but .img instead of .zip in the commands.
    My bad sorry
    Thanked by:
  24. #24
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    Its been a long day
    The command is ./fastboot boot recovery clockwork4847484747whatever.img
  25. #25
    Its been a long day
    Okay . . . as I showed above, that's not quite the filename I have, but I assume I use the filename I downloaded? (And I can go be sure I get the actual CW Touch img, too.)
