DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for LG Nexus 4!
Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Like Tree7Likes
  1. #26
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    524 Global Posts
    ROM
    Stock
    Default
    I have a mac so I am unsure if wug's tool kit will work. I have unlocked and rooted already. Not sure how to confirm root but other apps that require root don't protest. Clockwork recovery worked once on the backup, after that I've been killing the droid.
    Sent from my Galaxy Nexus
  2. #27
    Posts
    Global Posts
    524 Global Posts
    ROM
    Stock
    Default
    Also when I try to reboot into recovery I get the red exclamation. I have followed cyber warrior addendum to rename the system file, can't remember the name, to .bak but that hasn't helped.
  3. #28
    chubb's Avatar
    Posts
    ROM
    Stock Xoom, Nexus 4 AOKP
    Default
    Looks like the op got bored with his own thread already
  4. #29
    Posts
    Global Posts
    524 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by chubb View Post
    I guess I did hijack this thread, my apologies to all. I have the same feelings as the OP and when I saw title I got carried away.
  5. #30
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default Re: bored and wanna flash a rom but scared
    Flashing is not that complicated. Sure, there's a lot of craziness that goes on, but the concepts are brutally simple. Want to flash? You have to clear out your old stuff first, so you must wipe your phone. Then you install the new stuff. Then you reboot the phone. Any problems with it? Clear out and repeat!
    As long as you take your time, always wipe, and always have an escape mechanism (i.e. you have created a backup and can restore from that backup), you'll be fine. Trust me.
    Thanked by:
  6. #31
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    @Cigar_junkie sounds like either..
    1. As makesome suggested you just locked your CWR, you unlock it by hitting power and scrolling through a couple times.... or more likely....
    2. You don't actually have CWR flashed and what you are looking at is the stock recovery. Use the toolkit to flash the touch CWR image:
    Of if you know how to use fastboot just boot into the bootloader, connect, put that file in your fastboot folder and open a command window IN that folder, then just type:
    fastboot flash recovery nameoffile.img
    where you change nameoffile to the actual name (in this case recovery-clockwork-touch-5.8.0.2-toro.img)
    Thanked by 2:
  7. #32
    Posts
    Global Posts
    524 Global Posts
    ROM
    Stock
    Default
    Well I reread CW's guide and got back on track. I made the nandroid backup. I then bought mybackup pro and tried to backup data and apps. Chrome and one other app kept causing mybackup pro to chuck a wobbly. When I was finally ready to flash I ran out of time.
  8. #33
    asmallchild's Avatar
    Posts
    Global Posts
    1,553 Global Posts
    ROM
    4.1
    Quote Originally Posted by makesome View Post
    When you go into recovery mode you have to use the up and down volume buttons to select you're option then the power button to actually select it. Also if on Cwm you happen too hold the up/down buttons in( I made this mistake )it malfunctions and you should then touch then again to cancel this... the select power button won't work....
    Nice, I've made this mistake a couple of times, didn't realize this was the cause
  9. #34
    turninginward's Avatar
    Posts
    Global Posts
    74 Global Posts
    ROM
    Liquid
    Default
    Yep it scared the crap outta me I was trying to flash radios had to do 2 battery pulls till I figured out that gem! I thought my phone was toast.
    Sent from my horizon gnex that now farts rainbows and jelly beans hopefully... get it...?
