- 06-02-2012, 02:05 PM
Thread Author #26
Re: Unlocked and Rooted Using Cyber Warrior's Method - OTA 4.0.4
Thanks, I asked on several threads and no one suggested that I do that and I wouldn't know how to do that without someone telling me how anyhow. Everyone suggested that I use Wugs and told me that I wouldn't lose my pictures.
Thanks for the warning, just trying to warn others. - 06-02-2012, 02:19 PM #27Former moderator & advisor.
HTC - the One to rule them all.
- 06-02-2012, 02:25 PM
Thread Author #28
- 06-02-2012, 02:26 PM #29Former moderator & advisor.
Thread Author #30
- 06-02-2012, 02:35 PM #31Former moderator & advisor.
- 06-02-2012, 02:37 PM
Thread Author #32
- 06-02-2012, 02:39 PM #33Former moderator & advisor.
- 06-02-2012, 02:46 PM
Thread Author #34
- 06-02-2012, 02:55 PM #35
See bolded parts.... The recovery image was all you needed to flash. Flashing back to stock, as you did, is completely different and not what dmmarck said to do at all.
I understand it can be confusing and mistakes can be made if you aren't paying attention. Shame if you didn't have backups of your pics. - 06-02-2012, 03:01 PM #36
There are some programs available for recovering information from hard drives after being deleted but I really have no knowledge or person experience using them.
As for the toolkit not clarifying it will wipe or erase something, I look at it as common rule of thumb whenever your going to attempt anything that is going to unlock/root/modify system contents on your device I ALWAYS make a backup of my sdcard content before hand along with anything else like (exporting contacts to file, etc).
My opinion its your device, and you should be taking your own precautions to protect your data before attempting anything with Rooting & Hacking.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 06-02-2012, 03:14 PM #37
I will say that I did advise to unroot as well, but that was after the recovery advice. The op wanted to unroot and that's one of the methods mentioned along with the other guides.
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2Former moderator & advisor.
- 06-02-2012, 03:26 PM
Thread Author #38
- 06-02-2012, 03:44 PM #39
- 06-02-2012, 04:07 PM
Thread Author #40
- 06-02-2012, 05:38 PM #41
No I think if it wasn't mentioned that was a slip on the devs part.
Although it is also common knowledge that most devices with a boot loader that requires to be unlocked also means you wipe the device. Most cases if users do all the proper researching and required reading before attempting Rooting & Hacking they come to realize that this is common (most cases) during the unlock or process of placing a custom recovery on the device it also means you wipe the device.
It's unfortunate that it happened but we see it all the time and in the end it's the fault of the user for not reading enough, asking questions or simply backing up stuff just in case.
Before I became a Moderator and was an Advisor here at AC, I always preached time and time again in my guides and posts...
"if your ever unsure of something regarding rooting & hacking, stop...ask.. and wait for an answer before moving forward." This time it only cost you some pictures, your lucky compared to many that end up with bricks
Sent from my Nexus S 4G using Android Central ForumsLast edited by Paul627g; 06-02-2012 at 05:59 PM. Reason: Typos
- 06-02-2012, 06:04 PM
Thread Author #42
I was already unlocked and rooted. I was trying to unroot.
I was already rooted and had a custom recovery on my phone. I was trying to go back to stock recovery. I thought I needed to unroot to do that.
II would have backed up if it would have told me to because it was going to wipe my device. And I did ask questions and was told that rerooting would not wipe my pictures.Last edited by GNex Girl; 06-02-2012 at 08:46 PM.
- 06-02-2012, 06:30 PM #43
I'm guessing when you ran the toolkit and did whatever it was, it must have unrooted, locked and then unlocked the device which then wiped.
Again.. Example of why toolkits/one clicks aren't always the best option.. Learning to use Fastboot and do things manually is always the safest approach because you then ultimately control what is going to be flashed or done to the device by the commands you enter.
- 06-02-2012, 06:45 PM
Thread Author #44
I agree but I get the "waiting for device" problem when I try to use fastboot because the Samsung drivers aren't Windows XP friendly. I really hate Windows Vista and 7 with all of their permissions crap and don't want to ever have to use them, but I guess this is the price that I pay for sticking with XP.
- 06-02-2012, 06:58 PM
Thread Author #45
- 06-02-2012, 07:17 PM #46
Funny you should mention Windows XP. I have had best luck using Samsung drivers on my Windows XP desktop over my Vista and Win 7 laptops... Most devs will agree to that Win XP was a good version for interaction with drivers.
- 06-02-2012, 08:48 PM
Thread Author #47
- 06-03-2012, 01:10 PM #48
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI
Reply
