Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Paul627g
    Default ROM issues on G-Nex
    I have tried flashing three different ROMs (Redemption, Liquid & AOKP) on my G-Nex. All three of them were missing the notification bar & soft keys once I was done flashing. Can someone please tell me what I could be doing wrong?
  2. #2
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,021 Global Posts
    ROM
    AKOP M4 old geezer theme
    Default
    Are flashing any themes after wards. Usually a bad theme can wipe out the notification bar. Why not flash back to stock then redl a os and start from scratch
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    Google Nexus Class Devices (Nexus7, Nexus4, Galaxy Nexus lte VZW)...@moosc on twitter ...
  3. #3
    bbudnick5001's Avatar
    Posts
    ROM
    AOKP/CM10/AXIOM ROMs
    Default
    Quote Originally Posted by jroch75 View Post
    Are you following the directions for flashing each of these roms(wipe data,clear cache/dalvik)? My experience is some funky things can happen if you don't. Also maybe try a reboot. If you are flashing additional mods it seems to work better if you flash whatever rom and gapps, then reboot system, then go back to recovery and flash any mods or themes. Hope this helps I am still pretty new to all of this stuff too though
    Default Re: ROM issues on G-Nex
    i didn't do any wipes or clearing any caches. should i do this before or after flashing the rom?
  5. #5
    Paul627g's Avatar
    Posts
    Global Posts
    13,813 Global Posts
    ROM
    Milestone 1/Lean Kernel
    At bare minimum you should be wiping cache partition & dalvik cache. Most recommend a full data wipe, but some like to avoid this because it causes you to loose all your data (like a factory reset). This is known as a dirty wipe or dirty flash. It works most of the time but can have ill effects afterwards.
    Why your loosing the notification bar I'm not really sure.
    1. Do your wipes.
    2. Flash the ROM & GAPPS (if required) before leaving recovery
    3. Do a boot up and shutdown before making any other changes by means of flashing mods, kernels, etc.
    4. Any mods or themes you flash over the top of existing ROM, MUST be compatible with that ROM or things like the notification bar and other strange things can occur.
    5. Since there are 3 versions of GNex out there.. Verizon's GNex/GSM (TMobile/AT &T and International) and now Sprint's GNex make sure your flashing the correct ROM/kernels/themes/mods for your device. Sometimes devs don't do the best job at clearly marking which download is for which device.
    Thanked by 2:
    dmmarck likes this.
    thank you for all the great info! it is very much appreciated!
  7. #7
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Wipe everything, wipe always... C'mon.
    Every single OP for the ROMs instructs you to wipe data coming from any other ROM. Get in the habit of reading the OPs and following instructions or your going to have a hard time at this stuff.
    K not trying to beat on you, lol.. Consider it tough love
