Results 1 to 6 of 6
    Default ParanoidAndroid ROM for VZW G-Nex
    Anyone running ParanoidAndroid on G-Nex? Trying to flash this ROM bit can't find step by step instructions. New to ROMs and don't want to screw up my phone. Any help very appreciated!!!!!!
  2. #2
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Default Re: ParanoidAndroid ROM for VZW G-Nex
    The instructions are right in the OP:
    Under the very large INSTRUCTIONS sign
    Thanked by:
    Default
    Like I said.....new to this so this may be a dumb question. Am I supposed to install ROM then wipe data/cache? That doesn't make sense to me. I was expecting step 1.....then step 2..... and so on. I'm just gonna try to install and go from there. Thanks for the help!
  4. #4
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by mikekrafick View Post
    Again, just read the instructions as listed... it says wipe data, then flash rom, fix, and gapps, then wipe cache and dalvik cache, then reboot. Nowhere does it say to wipe data after flashing, lol.
  5. #5
    Default
    Just wanna add that if you are new at this I would recommend a ROM like AOKP or Liquid to start off with. Para is still in beta testing I believe and there will be bugs and what not. AOKP is usually solid a good start for newbies.
  6. #6
    kismet769's Avatar
    Posts
    Global Posts
    334 Global Posts
    ROM
    Synergy
    Quote Originally Posted by creccaj1 View Post
    Agreed.
    Paranoid is a great ROM, but there is A LOT of tweaking to do once you get it loaded to get apps and things to render properly. Definitely flash AOKP or Liquid for your first
B
