Results 1 to 8 of 8
Like Tree5Likes
  • 2 Post By zero neck
  • 1 Post By SeigaGen
  • 1 Post By DroidRat
  • 1 Post By gregs1213
    Default AOKP, Franco Questions...
    Hi everyone! So, I finally took the plunge on nexus the other night and installed my first custom ROM, kernel, and radios. Soooo much easier than I thought it was going to be, but still a PITA to have to wipe everything then re-install stuff...but I digress...my real question is around the ROM and kernel.
    I installed AOKP B37 and Franco's nightly #175....After getting everything set back up and fiddling around with all the new features, I went ahead and purchased Franco's kernel updater app. Well, now the question...do I use the CPU and governor settings in Franco's app or do I set them in the ROM control for AOKP, or does it matter? Same goes for Fast Charge.
    Other than that, am having fun playing with AOKP.
    Cheers and TIA!
  2. #2
    Default Re: AOKP, Franco Questions...
    Quote Originally Posted by DroidRat View Post
    Cheers and TIA!
    Doesn't fully matter but generally is better to enable as much on boot through your ROM as possible. I know AOKP has those functions so use those.
    Thanked by 3:
  3. #3
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Just be careful with setting things on boot - make sure to uncheck that if you flash a new kernel, bc you dont know if the new kernel will function correctly at those settings.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
    Thanked by 2:
    creccaj1 and dmmarck like this.
  4. #4
    Quote Originally Posted by zero neck View Post
    Very true.
  5. #5
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Also, stick to stock CPU voltage settings. Don't make the mistake I made and cause a short on the charger contacts. I had to call in for a replacement Nexus. You'll notice vast improvements with aokp and franco.
    Welcome to the brighter side of your Galaxy Nexus.
    Thanked by 2:
    dmmarck likes this.
    Thanks everyone, and good to know about the enabling/disabling things at boot regarding new ROMs.
    I actually unlocked & rooted when I got it on launch day and had just been waiting til I had enough time to read about ROMing and such. It really is very simple to do, I'd argue that unlocking and rooting were more time consuming.
    Anyway, thanks again! If it weren't for having to resetup everything, I'd play around with ROMs all the time. As it is though, I can see me riding AOKP for a while.
    Cheers!
    zero neck likes this.
  7. #7
    gregs1213's Avatar
    Posts
    Global Posts
    257 Global Posts
    ROM
    AOKP (M5) Franco (M4)
    Cheers!
    Use Nova Launcher or Apex.. You can save the settings.. Yeah I agree though.. I'd probably flash a lot more if I didn't have to deal with all of that.
  8. #8
    svfd757's Avatar
    Posts
    Global Posts
    834 Global Posts
    ROM
    Cm 10/Franco
    I am on this same set up, AOKP build 38 and Franco kernel 175. Sick combination. I am experiencing a huge increase in battery life. I highly recommend this combination
B
