[ROM] ///CMPLX_B1ACK_ADV8\\\ [AXi0M]
Jun 17, 2012
20
16
This is a ROM built from axi0m cmplx v1 to hold us over until DT has recovered.
All mods/tweaks are tested individually or in small groups to ensure bug-free stability::
Credit to DroidTh3ory > PrimeDirective
Features:
all axi0m cmplx v1 features included (listed on cmplx ROM thread)
native cmplx b1ack package [current inverted GAPPS][dark swype]
Min0r UI
Beats with XLoud 5.1 compatible with all players (that ive tested)
Dolby mobile & SRS
sexy text-to-speech (sorry Mrs steven hawking you're out)
multimedia/camera/AV playback tweaks
tons of cleanup.. lean & mean
removed logging & debuggerd
removed bugmailer
removed usage and statistics reporting
cleaned scripts, removed duplicate entries
added changes/tweaks to scripts
better multitasking of bandwidth during downloads
many new speed tweaks
Sony A-GPS (much faster gps lock)
other GPS tweaks (some credit DHO)
wifi channel 12-14 enabled (alpha testing)
system apks optimized for lower mem usage
removed search for apk from google search bar function (improved boot time & random CPU intense periods)
improved boot time
ads blocked
stock HD quality boot animation
Franco LINARO 185
bumped volume. this one goes to 11
Color safety control disabled
Trinity's color/gamma presets & disabled lame ass color safety controls
internal tweaks for better deep sleep/battery
extensive re prioritized system processes for NO LAG
low/no signal tower polling interval for battery
new browser 4.0.4 with my optimizations merged (AOKP)
new camera app w/ my xml edits (AOKP)
optimized apex 1.2.1
increased vibration
a root capable file manager
removed wallpapers from launcher to decrease memory usage...
optional Droidth3ory wallpaper pack provided below
optional Svoice Svideo addon package provided below. updated and bugsquashed svoice.
file system enhancements for greatly improved I/O & battery
SQLite optimized
Brand new Dalvik cache system
on install defrag & weekly defrag to keep the butter clean
setupwizard prefers wifi with poor signal
deuces
etc etc etc
CHANGELOG ADV-8:
a basic change log. just hitting the highlights.
smashed bugs. a lot of bugs.
fixed missing permissions
updated scripts
boot time improved, again
lobst3r quality butter.
updated gapps
updated other apps
facelock moved to separate flashable addon
fixed mem configuration that was not working properly
apollo swapped for music2.apk. PM me for the version from ADV7 if needed
LEANED out. if it wasn't removed it was improved. full rom = ~130 megs now
new boot animation (wythdryden)
working on for upcoming releases:
adding theme chooser support (halp plz!!)
new charging 100 .png charging animations (finished, need to compile)
backup script for user dictionary #crackflasher love (testing)
AVCRP 1.3 support
new set of tweaks to test for ADV9
try to remove lag from pin unlock
requests?
ISSUES:
Fixed in 8.1
INSTRUCTIONS:
1) Download
2) reboot into CWM recovery
3) FLASH!
4) $$ profit $$
5) optional: reboot recovery, flash add-on packages, kernels, etc
Files:
AXi0M CMPLX B1ACK ADV8.1:
mirror 1) ROMBOT!!
MD5 = 1f36682d75a6517efce45f20e31a50c
AXi0M CMPLX B1ACK ADV7:
mirror 1) ROMBOT!!
ADD-ONs for ADV8
Facelock mirror 1 facelock software
add-on pack mirror 1 Svoice/Svideo, news&weather w/ transparent widget, cm9 deskclock
productivity pack v2 mirror 1 inverted email/echange, stock b1ack keyboard, etc
play music from adv7 mirror 1 b1ack playmusic w/ transparent widget & beats status icon
WythDryden's boot animations:
http://www.droidhive...-by-wythdryden/
Main thread for cmplx b1ack adv here
if you like my work please DONATE HERE
20
16
Reactions: zero neck
bbudnick5001
117
18
Been running it all day! Keyboard is a little tough to get used too and seems a little laggy at times though. Also gmail is really hard to read but I'm sure if I wanted I could just uninstall then reinstall through play store to get the stock app back. Also I noticed there is no boot animation just a black screen. Doesn't bother me at all. Maybe I screwed up a setting or something. Either way I'm sure I'll be flashing something soon anyways:D . Thanks for all your hard work!
Jun 17, 2012
20
16
You're the first that can't see the boot animation on 3 forums. sorry? also, the keyboard shouldn't be laggy at all. I reprioritized the CPU threading for the entire list of system processes to remove lag. that's one of the reasons this rom has some lobst3r quality butter in it. describe steps so i can reproduce it and i'll take a look.
DB12088
197
17
I am not able to use the mirror for the email , it takes me to Google drives home page
Sent from my GT-I9300 using Android Central Forums
bbudnick5001
117
18
Not sure which steps you mean? I flashed a HD quality stock boot animation that I found on my sd card and that didn't work either:confused:
Jun 17, 2012
20
16
I had the same problem trying to make different boot anis. try opening up the desc file and lowering the framerate. you're phone must not like higher frame rates. similar to some phones dont like undervolting/overclocking
Reactions: bbudnick5001
bbudnick5001
117
18
Yeah I'm still running it too:D. I flashed the HYBRYD M2 today but had to restore back to this. I just missed all the black theming too much!
DB12088
197
17
Had to restore to my previous Rom due to a mistake I made I went to dl the email add on pack and it is taking me to The Google drive home page even if I try in desktop mode please advise
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Try downloading on a computer?
dumpsterrentals38
