Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By fire125k
    fire125k's Avatar
    Posts
    Global Posts
    31 Global Posts
    Default Help can't mount sd card!!!
    I was going to install new Rom and did a wipe when I went to install from SD card I get Can't mount /sdcard If I go to mount sdcard I get Error mounting /sdcard!!!! WHAT CAN I DO!!!!
  2. Thread Author  Thread Author    #2
    fire125k's Avatar
    Posts
    Global Posts
    31 Global Posts
    Default Re: Help can't mount sd card!!!
    ok I'm back up and running... If anyone ever runs into that problem search for Galaxy Nexus Toolkit v7.0 I was able to flash stock from the fastboot then reinstall CWM then flash the new Rom. It was very easy!!! Only down fall is I lost everything on the internal SD
    dmmarck likes this.
  3. #3
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by fire125k View Post
    It happens. Good to see you're ok now though!
  4. #4
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Do me a favor--elaborate on how you got around this.
  5. #5
    Bleezy's Avatar
    Posts
    Global Posts
    277 Global Posts
    ROM
    4.1.1 JB
    I didnt think Gnex has an SD card. Its all internal memory, no?
    Current Set up: Galaxy Nexus on JellyBro's latest CM10 nightly build
  6. #6
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    My apologies about this being a third post in a row, but I'd like to offer some information for those who stumble across this thread.
    I had this exact issue happen during TiBu restore after I flashed a rom. TiBu froze up and rebooted the phone into oblivion. I manually rebooted into recovery and nothing would mount; no roms would install; and unfortunately, no backups would restore.
    To solve the issue, I Googled a bit and saw two frames of logic--you need to flash the stock recovery again because this "remounts" and "rereads" everything, OR you need to go back to stock. I chose the latter.
    Using Ubuntu 12.04, restoring the factory images was a piece of cake. I pushed CWM Touch (in part because I believed my prior recovery, TWRP, was not a bit too blame for things, fairly or unfairly), reset everything and here I am again, rooted with Jelly Bean.
    So if you stumble across this thread, PLEASE be careful and get back to stock. It works, I can 100% guarantee it .
