Results 1 to 11 of 11
- 06-29-2012, 06:25 PM
Thread Author #1
battery drain with jelly bean
Never had a problem with ICS on my VZW Nexus. I usually leave 4G off unless I need it and could easily get 24 hours on a single charge.
I noticed after I flashed JB, my battery life is horrible. I am currently at 53% after 3 hours off the charger, and I didn't even touch my phone.
I did wipe data/cache/dalvik before install, and i did apply the WiFi fix.
Anything else? - 06-29-2012, 06:33 PM #2
Re: battery drain with jelly bean
Sounds like you need a different kernel? What are you currently running?
Former moderator & advisor.
HTC - the One to rule them all.
- 06-29-2012, 06:53 PM #3
- 06-29-2012, 07:08 PM
Thread Author #4
- 06-29-2012, 07:28 PM #5
- 06-29-2012, 08:37 PM
Thread Author #6
- 06-29-2012, 09:34 PM #7
This thread in the Rooting/ROMs/Hacks section has all the information on 4.1 for the Nexus. Click here to go to the post with kernels. I believe he was referring to the 210 kernel, mistakenly typing 201. If so, .
You can find the stock kernel in that post, too. If you do decide to try out Franco's work, however, keep in mind the "note" from that post:
Note - at the moment, set on boot doesn't work. Of greater concern is the fact that when you "reboot," the MAX CPU in his franco.Kernel updater app "automatically sets" at 1200 MHz. You want to change this immediately, primarily because that 1200 MHz option is not a supported option.Represent yourself well; you never know what might happen. And try out the new Android Central app!
Softbricking be damned. - 06-29-2012, 09:45 PM
Thread Author #8
is there much of a difference in the kernel supplied with Vicious v2 and Franco 210?
- 07-04-2012, 06:52 PM #9
Here's mine with stick 4.1 kernel.
Sent from my Galaxy Nexus - 07-05-2012, 08:42 AM #10
do a google search for better battery stats. there is a free version on that other site not to be mentioned here, or paid version on the market.
i used this app to see if i had any partial wakelocks. turned out Maps and "equalizer" was keeping my phone awake and chewing through battery.
i deleted "maps" from system app, rebooted, and downloaded it from the play store, and that fixed that (also signed in and out of latitude). but equalizer was still keeping me awake. so i uninstalled that, and now i am just as good on battery as ICS was.You know your rooted when bootloops don't scare you anymore. - 07-05-2012, 08:44 AM #11
I personally just removed the ROM and started from the beginning. This seemed to solve my battery problems with JB on my Nexus. Also seemed to fix other issues.
Reply
