Results 1 to 7 of 7
    Linebarrel86's Avatar
    Posts
    Global Posts
    216 Global Posts
    ROM
    Stock
    Default Roaming Indicator Off/Battery Drain
    Have been using the Viscious ROM and the stock kernel
    3.0.31- franco.Kernel-384GPU
    For some reason, I have 'Roaming Indicator Off' attached to my notification shade and it's draining my battery in a pretty big way.
    Anyone who can help me fix this?
  2. #2
    oxymoron's Avatar
    It's been real...
    Posts
    Default
    Haven't experienced this, but do you have roaming enabled in your settings? You incur no charges unless leaving the US. Try toggling that, perhaps? Or set it to home only?
    Good luck.
    Jellybeanin' on tapatalk
    Posts
    Global Posts
    216 Global Posts
    ROM
    Stock
    Default Re: Roaming Indicator Off/Battery Drain
    No, I don't have roaming enabled. And I have the system set to Home only.
  4. #4
    oxymoron's Avatar
    It's been real...
    Posts
    I don't know, bud. Have you tried wiping cache and dalvik, and rebooting? It's a good practice to follow anyway. I wipe my cache a few times a week.
  5. #5
    Have the same issue and 0 insight to provide.
    Just letting you know you aren't alone
  6. #6
    Are you on V2 or V3?
  7. #7
    sytech55's Avatar
    Posts
    ROM
    Vicious Jelly Bean V3
    I'm having the same issue. Using Vicious Jelly Bean v3 with faux kernel.
    Did the wipes and all.
B
