I'm running into an permission denied issue. Any ideas? I'm also not seeing an option for a toro build.
cj@Chimera:~/WORKING_DIRECTORY$ lunch
You're building on Linux
Lunch menu... pick a combo:
1. full-eng
2. full_x86-eng
3. vbox_x86-eng
4. full_grouper-userdebug
5. mini_armv7a_neon-userdebug
6. mini_armv7a-userdebug
7. full_wingray-userdebug
8. full_crespo-userdebug
9. full_maguro-userdebug
10. full_panda-userdebug
Which would you like? [full-eng] 9
find: `vendor': Permission denied
make: stat: vendor/samsung/tuna/BoardConfigVendor.mk: Permission denied
make: stat: vendor/samsung/maguro/BoardConfigVendor.mk: Permission denied
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION=4.1.1
TARGET_PRODUCT=full_maguro
TARGET_BUILD_VARIANT=userdebug
TARGET_BUILD_TYPE=release
TARGET_BUILD_APPS=
TARGET_ARCH=arm
TARGET_ARCH_VARIANT=armv7-a-neon
HOST_ARCH=x86
HOST_OS=linux
HOST_OS_EXTRA=Linux-3.2.0-26-generic-x86_64-with-Ubuntu-12.04-precise
HOST_BUILD_TYPE=release
BUILD_ID=JRO03C
OUT_DIR=out
I had that happen on my first compile--try changing the permissions of the vendor folder or try using "sudo su."
I solved it by using the long way--I changed ownership to everything by typing this in:
(Use your username, not mine obviously lol)
(Make sure to have a space after your username/before the file/folder!)
And then after typing that, I dragged and dropped each folder/file on each level of the /vendor folder. Thankfully, that worked. I'm sure there's a way to do it quicker and more efficiently (it was very late at night, so sue me
), but that worked for me.
EDIT: I'm a dummy, you can do this as well and it should work (my apologies
sudo chown -R dmmarck /vendorfolderhere
You can also change permissions with chmod instead of chown.
