[GUIDE][Ubuntu] Compiling Android from Source
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
I sync'd the 4.1.1_r1 branch, entered "full_toro-userdebug" at the lunch menu since it wasn't listed, ran make otapackage, and the result is named full_toro-ota-eng.lordbah.zip. I wasn't expecting to see "eng" there but "userdebug".
That's completely normal :).
anon(93769)
10
I'm having the same issue. After the error message, it continues like it's building, but only runs for a couple minutes and doesn't seem to actually produce anything. (i.e. no .zip or .img files using variations of "make -j#" and "make -j# otapackage")
Everything else seems to have run smoothly, and I can't find any issues with anything I downloaded for the build environment. Anyone have any ideas?
PS: This guide is phenomenal, I don't post much on here but I've been around for a little while and this is by far the most comprehensive tutorial I've ever seen. Kudos, D!
The link posted earlier had the resolution; you need to edit the file guava/src/com/google/common/collect/Maps.java and replace lines 228/229 with what's shown in green. See below:
- public static <C, K extends C, V> TreeMap<K, V> newTreeMap(
- @Nullable Comparator<C> comparator) {
+ public static <K, V> TreeMap<K, V> newTreeMap(
+ @Nullable Comparator<? super K> comparator) {
Reactions: dmmarck
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Thanks! OP's updated with updated fixes/tricks. Also added a neat CM compiler app, will be test driving it this week.
anon(93769)
10
I was able to complete my build, installed it, and at the same time installed a certain gapps and they appear to work. I am able to install market apps/use gmail. Not sure if it's OK to post which gapps I used though. Thank you, dmmarck!
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Sure, which GAPPs did you use?
And congrats!
KWKSLVR
860
4
18
To make up for my useless rambling earlier, on my build using Ubuntu 10.04, the methods listed in the OP for Java didn't work. What worked for me was:
sudo add-apt-repository ppa:sun-java-community-team/sun-java6
sudo apt-get update
sudo apt-get install sun-java6-jdk
Also, this last line was unnecessary for me, but apparently you can also type this if need be:
sudo update-java-alternatives -s java-6-sun
Hopefully that helps the next person that has issues. I discovered that tip from here.
Reactions: dmmarck
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Thank you! That should work with 12.04 as well. I'll put a link in the OP to this very post and that source.
Thanks again, I appreciate it!
Reactions: KWKSLVR
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Give it some time; it may be hanging. If it sits there for an hour or so, then I would probably wipe out your WORKING_DIRECTORY and start anew. It's fairly difficult to get a good build out of a directory that hangs like that, for it could have bad stuff (it's just safer to start over really; yes, it can be done as is, but still).
pitbrawlzant
4
Ok thanks
cj100570
Spoken Word?
Nov 12, 2009
417
24
What follows is a series of head scratching errors that all the Googling in the world hasn't helped me with:
find: `src': No such file or directory
PRODUCT_COPY_FILES device/generic/goldfish/data/etc/apns-conf.xml:system/etc/apns-conf.xml ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_MissedCall.ogg:system/media/audio/notifications/F1_MissedCall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_New_MMS.ogg:system/media/audio/notifications/F1_New_MMS.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_New_SMS.ogg:system/media/audio/notifications/F1_New_SMS.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Buzzer.ogg:system/media/audio/alarms/Alarm_Buzzer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_01.ogg:system/media/audio/alarms/Alarm_Beep_01.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_02.ogg:system/media/audio/alarms/Alarm_Beep_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Classic.ogg:system/media/audio/alarms/Alarm_Classic.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_03.ogg:system/media/audio/alarms/Alarm_Beep_03.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Rooster_02.ogg:system/media/audio/alarms/Alarm_Rooster_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Classic_02.ogg:system/media/audio/ringtones/Ring_Classic_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Digital_02.ogg:system/media/audio/ringtones/Ring_Digital_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Synth_04.ogg:system/media/audio/ringtones/Ring_Synth_04.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Synth_02.ogg:system/media/audio/ringtones/Ring_Synth_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Beat_Box_Android.ogg:system/media/audio/notifications/Beat_Box_Android.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Heaven.ogg:system/media/audio/notifications/Heaven.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/TaDa.ogg:system/media/audio/notifications/TaDa.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Tinkerbell.ogg:system/media/audio/notifications/Tinkerbell.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Effect_Tick.ogg:system/media/audio/ui/Effect_Tick.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressStandard.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressSpacebar.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressDelete.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressReturn.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/VideoRecord.ogg:system/media/audio/ui/VideoRecord.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/camera_click.ogg:system/media/audio/ui/camera_click.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BeatPlucker.ogg:system/media/audio/ringtones/BeatPlucker.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CaffeineSnake.ogg:system/media/audio/notifications/CaffeineSnake.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BentleyDubs.ogg:system/media/audio/ringtones/BentleyDubs.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BirdLoop.ogg:system/media/audio/ringtones/BirdLoop.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CaribbeanIce.ogg:system/media/audio/ringtones/CaribbeanIce.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CurveBall.ogg:system/media/audio/ringtones/CurveBall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/EtherShake.ogg:system/media/audio/ringtones/EtherShake.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/FriendlyGhost.ogg:system/media/audio/ringtones/FriendlyGhost.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/GameOverGuitar.ogg:system/media/audio/ringtones/GameOverGuitar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Growl.ogg:system/media/audio/ringtones/Growl.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/InsertCoin.ogg:system/media/audio/ringtones/InsertCoin.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/LoopyLounge.ogg:system/media/audio/ringtones/LoopyLounge.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/LoveFlute.ogg:system/media/audio/ringtones/LoveFlute.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/MidEvilJaunt.ogg:system/media/audio/ringtones/MidEvilJaunt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/MildlyAlarming.ogg:system/media/audio/ringtones/MildlyAlarming.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/NewPlayer.ogg:system/media/audio/ringtones/NewPlayer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises1.ogg:system/media/audio/ringtones/Noises1.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises2.ogg:system/media/audio/ringtones/Noises2.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises3.ogg:system/media/audio/ringtones/Noises3.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/OrganDub.ogg:system/media/audio/ringtones/OrganDub.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/RomancingTheTone.ogg:system/media/audio/ringtones/RomancingTheTone.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SitarVsSitar.ogg:system/media/audio/ringtones/SitarVsSitar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SpringyJalopy.ogg:system/media/audio/ringtones/SpringyJalopy.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Terminated.ogg:system/media/audio/ringtones/Terminated.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/TwirlAway.ogg:system/media/audio/ringtones/TwirlAway.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/VeryAlarmed.ogg:system/media/audio/ringtones/VeryAlarmed.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/World.ogg:system/media/audio/ringtones/World.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DearDeer.ogg:system/media/audio/notifications/DearDeer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DontPanic.ogg:system/media/audio/notifications/DontPanic.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Highwire.ogg:system/media/audio/notifications/Highwire.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/KzurbSonar.ogg:system/media/audio/notifications/KzurbSonar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/OnTheHunt.ogg:system/media/audio/notifications/OnTheHunt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Voila.ogg:system/media/audio/notifications/Voila.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CrazyDream.ogg:system/media/audio/ringtones/CrazyDream.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DreamTheme.ogg:system/media/audio/ringtones/DreamTheme.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/LowBattery.ogg:system/media/audio/ui/LowBattery.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Dock.ogg:system/media/audio/ui/Dock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Undock.ogg:system/media/audio/ui/Undock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Lock.ogg:system/media/audio/ui/Lock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Unlock.ogg:system/media/audio/ui/Unlock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/moonbeam.ogg:system/media/audio/notifications/moonbeam.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/pixiedust.ogg:system/media/audio/notifications/pixiedust.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/pizzicato.ogg:system/media/audio/notifications/pizzicato.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/tweeters.ogg:system/media/audio/notifications/tweeters.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Big_Easy.ogg:system/media/audio/ringtones/Big_Easy.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Bollywood.ogg:system/media/audio/ringtones/Bollywood.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Cairo.ogg:system/media/audio/ringtones/Cairo.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Calypso_Steel.ogg:system/media/audio/ringtones/Calypso_Steel.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Champagne_Edition.ogg:system/media/audio/ringtones/Champagne_Edition.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Club_Cubano.ogg:system/media/audio/ringtones/Club_Cubano.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Eastern_Sky.ogg:system/media/audio/ringtones/Eastern_Sky.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Funk_Yall.ogg:system/media/audio/ringtones/Funk_Yall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Savannah.ogg:system/media/audio/ringtones/Savannah.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Gimme_Mo_Town.ogg:system/media/audio/ringtones/Gimme_Mo_Town.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Glacial_Groove.ogg:system/media/audio/ringtones/Glacial_Groove.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Seville.ogg:system/media/audio/ringtones/Seville.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/No_Limits.ogg:system/media/audio/ringtones/No_Limits.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Paradise_Island.ogg:system/media/audio/ringtones/Paradise_Island.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Road_Trip.ogg:system/media/audio/ringtones/Road_Trip.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Shes_All_That.ogg:system/media/audio/ringtones/Shes_All_That.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Steppin_Out.ogg:system/media/audio/ringtones/Steppin_Out.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Third_Eye.ogg:system/media/audio/ringtones/Third_Eye.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Thunderfoot.ogg:system/media/audio/ringtones/Thunderfoot.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BussaMove.ogg:system/media/audio/ringtones/BussaMove.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CrayonRock.ogg:system/media/audio/ringtones/CrayonRock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DancinFool.ogg:system/media/audio/ringtones/DancinFool.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DonMessWivIt.ogg:system/media/audio/ringtones/DonMessWivIt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/HalfwayHome.ogg:system/media/audio/ringtones/HalfwayHome.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Playa.ogg:system/media/audio/ringtones/Playa.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SilkyWay.ogg:system/media/audio/ringtones/SilkyWay.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Effect_Tick.ogg:system/media/audio/ui/Effect_Tick.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressStandard.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressSpacebar.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressDelete.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressReturn.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/VideoRecord.ogg:system/media/audio/ui/VideoRecord.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/camera_click.ogg:system/media/audio/ui/camera_click.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/camera_focus.ogg:system/media/audio/ui/camera_focus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/LowBattery.ogg:system/media/audio/ui/LowBattery.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Dock.ogg:system/media/audio/ui/Dock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Undock.ogg:system/media/audio/ui/Undock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Lock.ogg:system/media/audio/ui/Lock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Unlock.ogg:system/media/audio/ui/Unlock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Sceptrum.ogg:system/media/audio/ringtones/Sceptrum.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/alarms/ogg/Cesium.ogg:system/media/audio/alarms/Cesium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/alarms/ogg/Plutonium.ogg:system/media/audio/alarms/Plutonium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressStandard_120.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressSpacebar_120.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressDelete_120.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressReturn_120.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Capella.ogg:system/media/audio/notifications/Capella.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/CetiAlpha.ogg:system/media/audio/notifications/CetiAlpha.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Polaris.ogg:system/media/audio/notifications/Polaris.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Pollux.ogg:system/media/audio/notifications/Pollux.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Procyon.ogg:system/media/audio/notifications/Procyon.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Aquila.ogg:system/media/audio/ringtones/Aquila.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/ArgoNavis.ogg:system/media/audio/ringtones/ArgoNavis.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Carina.ogg:system/media/audio/ringtones/Carina.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Centaurus.ogg:system/media/audio/ringtones/Centaurus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Cygnus.ogg:system/media/audio/ringtones/Cygnus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Draco.ogg:system/media/audio/ringtones/Draco.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Machina.ogg:system/media/audio/ringtones/Machina.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Orion.ogg:system/media/audio/ringtones/Orion.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Pegasus.ogg:system/media/audio/ringtones/Pegasus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Pyxis.ogg:system/media/audio/ringtones/Pyxis.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Rigel.ogg:system/media/audio/ringtones/Rigel.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Scarabaeus.ogg:system/media/audio/ringtones/Scarabaeus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Solarium.ogg:system/media/audio/ringtones/Solarium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Adara.ogg:system/media/audio/notifications/Adara.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Arcturus.ogg:system/media/audio/notifications/Arcturus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Bellatrix.ogg:system/media/audio/notifications/Bellatrix.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Hojus.ogg:system/media/audio/notifications/Hojus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Lalande.ogg:system/media/audio/notifications/Lalande.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Mira.ogg:system/media/audio/notifications/Mira.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Proxima.ogg:system/media/audio/notifications/Proxima.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Shaula.ogg:system/media/audio/notifications/Shaula.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Spica.ogg:system/media/audio/notifications/Spica.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Tejat.ogg:system/media/audio/notifications/Tejat.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Upsilon.ogg:system/media/audio/notifications/Upsilon.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Vega.ogg:system/media/audio/notifications/Vega.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Andromeda.ogg:system/media/audio/ringtones/Andromeda.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/CanisMajor.ogg:system/media/audio/ringtones/CanisMajor.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Girtab.ogg:system/media/audio/ringtones/Girtab.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Hydra.ogg:system/media/audio/ringtones/Hydra.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Perseus.ogg:system/media/audio/ringtones/Perseus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Themos.ogg:system/media/audio/ringtones/Themos.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/UrsaMinor.ogg:system/media/audio/ringtones/UrsaMinor.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Zeta.ogg:system/media/audio/ringtones/Zeta.ogg ignored.
PRODUCT_COPY_FILES device/samsung/toro/bcmdhd.cal:system/etc/wifi/bcmdhd.cal ignored.
PRODUCT_COPY_FILES device/sample/etc/apns-conf_verizon.xml:system/etc/apns-conf.xml ignored.
PRODUCT_COPY_FILES frameworks/native/data/etc/android.hardware.telephony.cdma.xml:system/etc/permissions/android.hardware.telephony.cdma.xml ignored.
PRODUCT_COPY_FILES device/samsung/tuna/bcmdhd.cal:system/etc/wifi/bcmdhd.cal ignored.
No private recovery resources for TARGET_DEVICE toro
host Java: guavalib (out/host/common/obj/JAVA_LIBRARIES/guavalib_intermediates/classes)
Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/emma_out/lib/classes-jarjar.jar
Copy: dx (out/host/linux-x86/obj/EXECUTABLES/dx_intermediates/dx)
Install: out/host/linux-x86/bin/aapt
Install: out/host/linux-x86/bin/aidl
external/guava/guava/src/com/google/common/collect/Maps.java:542: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
found : <K,V>java.util.TreeMap<K,V>
required: java.util.SortedMap<K,V>
SortedMap<K, V> onlyOnLeft = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:543: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
SortedMap<K, V> onlyOnRight = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:545: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
SortedMap<K, V> onBoth = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:547: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,com.google.common.collect.MapDifference.ValueDifference<V>>
required: java.util.SortedMap<K,com.google.common.collect.MapDifference.ValueDifference<V>>
target Export Resources: framework-res (out/target/common/obj/APPS/framework-res_intermediates/package-export.apk)
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
4 errors
make: *** [out/host/common/obj/JAVA_LIBRARIES/guavalib_intermediates/javalib.jar] Error 41
make: *** Waiting for unfinished jobs....
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
aapt: warning: string 'gsm_alphabet_default_charset' has no default translation in frameworks/base/core/res/res; found: ko
redstar427
22
The best way I've done it is simply editing within the zip.
Sent swiftly by Oliver using Android Central Forums
How do you edit within the zip?
I am running Kubuntu 12.04 and ARK will not let me edit anything in the zip, I have to extract to a folder first, make edits and re-zip, and then the installation aborts from cwm.
akbarramadhani12
