Results 1 to 25 of 25
- 07-18-2012, 03:58 AM
Thread Author #1
help please!!!!!!!
I have a galaxy nexus, it was given to me not working. When I try to turn it on there is a exclamation mark inside of a yellow triangle and on one side a pc and other side a phone.
So I was told it was rooted, a Rom was installe and when they tried to go back to stock it did this. I always had Motorola so I thougt Samsung would be as easy as Motorola to fastboot or sbf back to stock but its not as easy lol. So I tried everything I've read and nothinworks. I finally got Odin to recognize the phone, and when I try to flash the stock images it starts then sais
Initialization..
Get pit for mapping
Nand write start!!
Complete(write) operation failed.
Any help?? What am I doing wrong or missing?? Please!!! - 07-18-2012, 06:04 AM #2
- 07-18-2012, 06:08 AM #3
Re: help please!!!!!!!
Can you get the phone into fastboot... holding vol up and down and then holding the power button? If you can do that, then I would download Wugs toolkit and flash back to stock. You may need to install the drivers but the toolkit has everything that you will need to do that as well.
- 07-18-2012, 06:35 AM #4
As creccaj was saying... try to get into the bootloader/fastboot by pulling and replacing the battery, then holding BOTH volumes and power until you see the bootloader screen. If it won't go there and will only take you to Odin mode you can probably still fix it.. though Odin is an area I admittedly know nothing about dealing with.. Whoever you got this from did something incredibly dumb to it, btw.
Our other Advisor, Zero Neck, is more familiar with Odin and might be able to help if he gets here later. I'll do some asking and see if I can find a solution for you as well.
EDIT: You are sure you aren't holding volume down and power when you are trying to boot up? Because that brings you to the odin mode you are seeing... make sure you aren't doing that on your own...Last edited by 2defmouze; 07-18-2012 at 06:44 AM.
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI - 07-18-2012, 10:44 AM
Thread Author #5
- 07-18-2012, 12:09 PM #6
- 07-18-2012, 12:12 PM
Thread Author #7
- 07-18-2012, 12:21 PM #8
I've gotten some info from zero neck.. again I am not familiar with odin so I'm going to paste his response and hope you can work from it and it might be helpful (zero is a busy guy today but will possibly be around later to offer more help):
-- He needs a PC and an Odin program from xda, and he needs to do both PDA and phone to make it work correctly
-- There's PDA and phone files for Odin, he needs both
So I'd check xda, or if anyone knows where these files can be found and can link it would be appreciated. Sorry I can't offer more just yet, little busy on my end as well.. keep us updated.
[GUIDE] Nexus 4 - Unlock & Root | [GUIDE] Nexus 4 - Factory Image Restore | [GUIDE] Nexus 7 - Factory Image RestoreNeed a Dropbox? Use this link to sign up and both of us get free bonus space http://db.tt/YOHANuCI - 07-18-2012, 12:28 PM #9
- 07-18-2012, 12:37 PM
Thread Author #10
- 07-18-2012, 12:47 PM
Thread Author #11
- 07-18-2012, 01:08 PM
Thread Author #12
- 07-18-2012, 01:14 PM #13
:crossingfingers: great! Lol
Sent from my Galaxy Nexus using Tapatalk 2 - 07-18-2012, 02:50 PM
Thread Author #14
- 07-18-2012, 03:05 PM #15
- 07-18-2012, 03:21 PM
Thread Author #16
- 07-18-2012, 03:24 PM #17
- 07-18-2012, 03:26 PM
Thread Author #18
- 07-18-2012, 03:33 PM #19
Correct me if I'm wrong, but maybe if you go online and do the phone activation/switch from one device to a different device, that will get it going. That's what I did when I got my GNEX.
- 07-18-2012, 03:38 PM
Thread Author #20
- 07-18-2012, 03:39 PM
Thread Author #21
- 07-18-2012, 03:50 PM #22
Sounds like you might have one of the defective Nexi. I had one. Would constantly lose/not connect to LTE and give me that symbol over your network signal strength. Basically was forced to use it in 3G mode (turned off LTE) until I got a replacement device. Are you able to get a connection with your LTE radio turned off?
Sent from my Galaxy Nexus using Android Central Forums - 07-18-2012, 03:51 PM #23
If that doesn't work, I'd just wipe data/cache/dalvik, format system, and reinstall the rom/gapps.
Doesn't sound like it would fix it, but hey, it's worth a shot... - 07-18-2012, 04:08 PM
Thread Author #24
- 07-18-2012, 06:40 PM #25
Reply
