Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By davey11
  • 1 Post By davey11
  • 3 Post By scarryman04
    Default Backup help for first rooting
    Hey all, would appreciate any help you guys can give me on this. I'm rooting my verizon gnex for the first time to load up a jellybean rom. A friend (and most of the forums) have suggested using titanium backup to backup all my apps and data. However, it seems that you can only use that once you've already rooted. So is there no way to save all my apps/data through the first root?
  2. #2
    Default Re: Backup help for first rooting
    Try out wugs in the stickies above. I hear it does backups without root. Never used it so not 100% sure.
    Thanked by:
    zero neck likes this.
    thanks for the tip davey, i'll give it a shot. that's been the main reason i never rooted really. i'm crazy about my setup on my homescreens and spent so much time getting all my apps exactly how i want them in folders/etc that i hate to have to go through that all over again.
  4. #4
    Quote Originally Posted by Freido28 View Post
    I hear you man. All of us frequent rom flashers put up doing the setup dance with every new flash. It gets easier the more you do it. Its a small price to pay to have the latest software. And you want the latest stuff...its just gets better.
  5. #5
    scarryman04's Avatar
    Posts
    ROM
    Jelly Bean/ Thors ICS
    I can get all my apps/homescreen set up in under a hour...but I been crack flashin since the good ol OG Droid days lol
  6. #6
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    im good in about twenty min but i use hardly any apps and know every thing in settings i need to change. the one pain is logging into websites but sometimes you can get away with restoring data to your browser thru tibu. can be risky tho
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  7. #7
    Default
    My backup pro is pretty good! Check it out in the play store
  8. Thread Author  Thread Author    #8
    Default
    Thanks for the tips! Def gonna try my backup pro.
    Default
    Looks like a no-go for my backup pro. Says on the main page that the app data backup feature is only available if rooted.
  10. #10
    ConTejas's Avatar
    Posts
    ROM
    Super Beans n Kernels
    I like some other features of Nova Launcher over stock but the main reason I use it is it allows you to backup your homescreens. Wug's toolkit will make a backup but you can use this for extra peace of mind if you want. Not going to help you as far as your homesceens at this point but you could use Nova or Apex going forward. I took screenshots of each screen to help me remember before Nova and it wasn't too painful. Now it's a breeze.
    [BETA] Backup Wonder Machine (no root, ICS only)
  11. #11
    Posts
    ROM
    So root, make your back-up, then flash away.
  12. Thread Author  Thread Author    #12
    Default
    Thanks man. Definitely going to look into that.
  13. #13
    You are better off using a backup program and only use it to backup the apps. I have had countless problems when restoring apps and data. I only restored some apps with data and even those half the time I didn't bother. It will give you less headaches just to set them up again.
    You can always use a launcher like Nova or Apex and backup your homescreen settings like someone else said and titb to back up apps. Yea it's a pain to set everything back up but its become almost like a routine.
  14. Thread Author  Thread Author    #14
    yeah the more i hear from everyone the more i'm realizing i'm just going to have to deal with the small hassle. especially if it becomes more of a pain to backup/restore everything separately than it would to just redo it all myself.
