08-25-2013 02:45 PM
1,915 ... 5960616263 ...
tools
  1. EvanM3's Avatar
    Everyone with M1, can they try the clock thing I described?
    Go to Settings, then ROM Control, then Clock. Set "short press" (or whatever the hell the other option is that isn't long press), select "Alarms."
    Go to the home screen, pull down the notification drawer, and tap the clock. Force close?
    I tried it and I get nothing. On the other hand, long press for alarm works as it should. No force close though
    10-29-2012 07:59 PM
  2. nexusisneecesary's Avatar
    yes it happened to me earlier today
    10-29-2012 08:01 PM
  3. dmmarck's Avatar
    Does it popup with the alarm? Hmmm...I may do long press and see what's what. Thanks!
    - - - Updated - - -
    Thanks!
    10-29-2012 08:02 PM
  4. mraviator's Avatar
    Force close?
    That's affirmative. Force close here too.
    10-29-2012 08:24 PM
  5. dmmarck's Avatar
    Thanks, at least I know I'm not nuts lol
    10-29-2012 08:25 PM
  6. Patrick Schroedl's Avatar
    - - - Updated - - -
    Thanks!
    Since it might not be happening to everyone, something to try would be seeing if the issue changes depending on whether or not you actually have alarms set/turned on.
    10-29-2012 08:28 PM
  7. EvanM3's Avatar
    I set some alarms and then tried the short press. Still nothing. The alarms don't even open or anything. No force close.
    Long pressing the clock does work like it should.
    10-29-2012 08:33 PM
  8. dmmarck's Avatar
    It's so weird. Works like a charm on the grouper. In the end, it's a minor issue, but still--was looking forward to not having to open the app drawer for my alarms .
    10-29-2012 08:37 PM
  9. weasle543's Avatar
    Alarm clock worked this morning, I made it to work on time. :-)
    dmmarck likes this.
    10-30-2012 06:25 AM
  10. jmorosky's Avatar
    Short click FC'd for me the first time but has worked every other time I tried. But I also had alarms set for long click too.
    Sent from my Island using my Smoke Monster
    10-30-2012 08:01 AM
  11. weasle543's Avatar
    It would force close until I set the short and long press to something different.
    10-30-2012 08:17 AM
  12. finger11's Avatar
    So I'm about to flash Milestone 1. Which gapps should I be flashing with this ROM? Thanks guys!
    10-30-2012 09:24 AM
  13. 2defmouze's Avatar
    They are linked at the end of the download list on aokp.co
    10-30-2012 09:27 AM
  14. finger11's Avatar
    Right on, so that's how you know which to use.
    10-30-2012 09:41 AM
  15. mraviator's Avatar
    I was running MS1 for two days with no issues. Then I realized my Gmail emails weren't being pushed. Sure enough, sync was turned off. I can't say for sure this happened on its own, but has anyone experienced similar?
    10-30-2012 07:06 PM
  16. dmmarck's Avatar
    90% sure that with the new GAPPs, which require Gmail to be downloaded separately, that sync needs to be tapped/selected.
    10-30-2012 07:24 PM
  17. mraviator's Avatar
    Ahhh.... that also explains why I had to download gmail separately. Thanks.
    10-30-2012 07:33 PM
  18. MRW1215's Avatar
    While not AOKP-related, I'm curious, is there anything in the franco kernel app that I should play around with in the settings that will boost performance/ battery life in any way?
    Edit: I managed to dig up an old picture from dmmarck, and by matching the settings as closely as possible, it seems my battery is doing a lot better! This was his pic, just for reference:
    10-31-2012 10:18 AM
  19. jova33's Avatar
    I think jelly bean is supposed to work best with interactive.
    Sent from my wireless telephonic device.
    10-31-2012 09:55 PM
  20. MRW1215's Avatar
    Really? Hm. Its been working fine for me with "ondemand". Then again, I don't know what any of those settings actually mean/ do at all, so...
    10-31-2012 10:49 PM
  21. jova33's Avatar
    Neither do I lol. I just know what I hear. Like people have been saying the x governors are choppy. Interactivex, hotplugx, and so on.
    10-31-2012 11:40 PM
  22. dmmarck's Avatar
    Stock jelly bean governor is interactive, that's why .
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
    10-31-2012 11:50 PM
  23. MRW1215's Avatar
    So, is there anything I should be aware of, by setting mine to "ondemand"? What does that mean for my phone, and what is the difference between using "ondemand" or "interactive"? Is there some sort of noticeable difference at all?
    11-01-2012 10:09 AM
  24. anthony1117's Avatar
    Enjoying this ROM a lot. Found few bugs, my clock in the right crner and th one at the top of my pull down do not auto matically update the time.....Kinda confusing and frustrating,. Does anybody else have this problem or is it just me. SHould i try a reset and reinstall? Any suggestins would be awesome.
    11-04-2012 12:56 AM
  25. Explicit's Avatar
    Mine changes perfectly. Try a full wipe and reinstall
    11-04-2012 01:15 AM
