Page 62 of 77 FirstFirst ... 59606162636465 ... LastLast
Results 1,526 to 1,550 of 1915
Like Tree420Likes
  1. #1526
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Seems to be working perfectly fine now. So whatever.
    Also is there a good Franco kernel that will give me good battery life?
  2. #1527
    Set your governor to anything but interactive.
    And then look at a logcat.
    Your phone will be crying about input boost endlessly.
    The interactive governor is specifically tailored and the roms are specifically tailored to work with it.
    The primary change would be this "input boost" that is supposed to ramp up your CPU to 700mhz+ the second your screen is touched.
  3. #1528
    Getting a lot of system UI crashes. Anyone else? Also pretty bad battery life. With M1 and Franco M6. This is on full clean wipe.
  4. #1529
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by dc5_alex View Post
    Did you restore system data?
    And by clean wipe you mean you:
    Wiped data/factory reset
    wipe caches
    wiped system
    (overkill maybe, but the wipe data/factory reset is the important one) ?
  5. #1530
    Quote Originally Posted by 2defmouze View Post
    wipe caches
    wiped system
    I did a dirty to M1 and Franco M6, no issues, and battery life is a little better but not great, had better battery life when I was using JB ports (Jakeday).
  6. #1531
    wipe caches
    wiped system
    Nope didn't restore system data. And yes I wiped all those other things. Might re-flash with clean install again tonight and see how it goes -_-
  7. #1532
    bdGDL08's Avatar
    Posts
    Global Posts
    241 Global Posts
    I've been doing dirty flashes since build 3 and have had no problems.
    Drew
  8. #1533
    For what it's worth, I flashed the new 4.2 GAPPs zip (after making a backup naturally) and have had no problems so far, so it looks like AOKP JB 1 works fine with it.
  9. #1534
    So, since 4.2 is still Jellybean, is AOKP just going to go to build 6 when they update to 4.2? Or will they go back to "build 1"?
  10. #1535
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    I believe they will continue with build 6.
    Brought to you by the Google Galaxy Nexus.
    Hit me up at the Android Developers Conference from December 4-7 in San Francisco.
    Motorola Droid Maxx
    Samsung Galaxy Nexus - RIP
    CM10 Jellybro Jelly Bean
    Asus Nexus 7
    AOKP JB Milestone 1
  11. #1536
    Is there a reason that AOKP has not been updating. When I click on the link to AOKP news is the OP of this thread my browser, Chrome, informs me that site is infected with malware. Can we expect this situation to be fixed soon. I was used to seeing many posts a day in this thread but now it goes days with no posts.
  12. #1537
    jova33's Avatar
    Posts
    Global Posts
    364 Global Posts
    It took them a couple of weeks before they put out anything after jelly bean source was released. They're working on it, just be patient.
    Sent from my wireless telephonic device.
  13. #1538
    The one I have noticed about AOKP is it may take a little longer than most others but they usually release a bug free ROM. I'll wait too see what they release. Jakeday would be a back up if AOKP fails yo deliver any thing new.
    Droid MAXX 32GB
    OS- 4.4 KK
    RIP- GNEX- you were fun to hack and install AOKP ROMS, but your time is over.
  14. #1539
    Quote Originally Posted by ShinyTop View Post
    noticed that too no matter what browser I choose. Hope it some sort of web hosting issue.
    Droid MAXX 32GB
    OS- 4.4 KK
  15. #1540
    bdGDL08's Avatar
    Posts
    Global Posts
    241 Global Posts
    The aokp site was hacked so they took it offline for a bit. It will be back up soon, but everything is still available on Androtransfer.
    Drew
    Thanked by:
  16. #1541
    Canuckfan's Avatar
    Posts
    ROM
    CM10 JellyBro | Franco M5
    Was anyone able to grab the AOKP 4.2 "preview" build and could provide a mirror? xoomdev released it on twitter but his dropbox links have been taken down due to too much traffic.
  17. #1542
    Quote Originally Posted by Canuckfan View Post
    Page 1358 of this thread has a mirror and a new Steve Spear build. I havent had a chance to flash these, but will be later today. Happy flashing!
    http://rootzwiki.com/topic/19302-aok...age__st__13570
    Thanked by 2:
  18. #1543
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    Global Posts
    2,106 Global Posts
    ROM
    SKAnkCM10/Milestone6
    Quote Originally Posted by Empty Hand View Post
    AOKP | toro | JB Milestone 1 - Device Threads - RootzWiki - Page 1358
    Nice!
  19. #1544
    jova33's Avatar
    Posts
    Global Posts
    364 Global Posts
    Vibrate when ringing option doesn't stick. Camera sounds can't be muted.
    Other than than, it's great. With most of the features I can't live without.
  20. #1545
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Quote Originally Posted by jova33 View Post
    http://img.tapatalk.com/d/12/11/24/8y8arybe.jpg
    For camera just navigate using Root Explorer or something similar to /system/media/audio/ui/ and rename the file 'camera_click.ogg'... I usually just add .bak to the end of it so I can undo it if I want at a later time
    Thanked by 2:
    oxymoron likes this.
  21. #1546
    Canuckfan's Avatar
    Posts
    ROM
    Quote Originally Posted by JkdJedi View Post
    Nice!
    How does the nightly compare to MMuzzy's JOP40C rom?
  22. #1547
    So far pure butter
    Sent from my Galaxy Nexus using Xparent Blue Tapatalk 2
  23. #1548
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    ROM
    There will be many...
    Has anyone had low speaker volume issues with the unofficial 4.2? I was running Mmuzzy's for awhile and had to leave it since the ringer volume was too low...
  24. #1549
    ConTejas's Avatar
    Posts
    ROM
    KK+Xposed+GB+Franco=Win
    ^^^Nope, but I've also been flashing DSP Manager (as always). EDIT: Noticed you specified the ringer. Still, mine is loud.
    Spear's 11/27 unofficial build is butter. Has some more goodies I've been missing. Namely the LTE toggle. Not sure if I didn't notice on 11/23 or 25, but the short press on/off and long press shortcut to settings are working properly too. I'm liking what the devs are doing with 4.2 more and more.
    Also, vibrate whilst ringing is working/sticking....along with custom vibrate.
  25. #1550
    Quote Originally Posted by ConTejas View Post
    Agreed! Here's a link:
    http://androtransfer.com/?developer=stevespear
    ConTejas likes this.
Tags for this Thread
