Page 63 of 77 FirstFirst ... 60616263646566 ... LastLast
Results 1,551 to 1,575 of 1915
Like Tree420Likes
  1. #1551
    ConTejas's Avatar
    Posts
    ROM
    Super Beans n Kernels
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Quote Originally Posted by Empty Hand View Post
    Agreed! Here's a link:
    http://androtransfer.com/?developer=stevespear
    I'm positive I dl'ed the 11/27 file, and I have lte toggle/circle mod/fixes that w were to be included in this build, but my version/build still says 11/25. Can you confirm yours does too. Running great so whatever. Just want to ensure I'm not crazy lol
    [ROM] Android Open Kang Project- Jelly Bean Style-uploadfromtaptalk1354053749799.jpg
  2. #1552
    I was just thinking, now that 4.2.1 is out, the big guns (aokp, cm) will take even longer to get official builds out.
  3. #1553
    ConTejas's Avatar
    Posts
    ROM
    Default
    Quote Originally Posted by davey11 View Post
    I have a feeling 4.2.1 just fixes the issues 4.2 broke and the devs have been working to fix. Although I saw the github page was rather large.
    davey11 likes this.
  4. #1554
    Quote Originally Posted by ConTejas View Post
    Jkd posted http://forums.androidcentral.com/ver...ml#post2371243
    The versions are coming out fasst. Bordering on ridiculous.
  5. #1555
    So many links!!! If I want aokp... What do I flash?
  6. #1556
    I got straight to rootzwiki where they all post. Also you can follow them on Twitter. Adamthecashew has a goo.im account under /dev.
    Sent from my wireless telephonic device.
  7. #1557
    10001110101's Avatar
    Posts
    Global Posts
    397 Global Posts
    ROM
    There will be many...
    Flashed the 1127 this morning. Lost my sd storage completely, oh well, clean slate.
    Vibrate while ringing won't stick, but damn is it smooth.
  8. #1558
    Quote Originally Posted by 10001110101 View Post
    Check data/media folder. You should find your sd card contents.
  9. #1559
    I haven't tried them yet, but new 11-28 "signed" gapps are up on goo.im.
    http://goo.im/gapps/gapps-jb-20121128-signed.zip
  10. #1560
    Wonder what's new.... is there anyway to get HDR pictures on the GNex?
  11. #1561
    RJV3's Avatar
    Posts
    Global Posts
    174 Global Posts
    Can someone confirm if the 11/28 new gapps for 4.2.1 works with this rom?
    - - - Updated - - -
  12. #1562
    They work
  13. #1563
    RJV3's Avatar
    Posts
    Global Posts
    174 Global Posts
    Need help. I did a nandroid back up before i flashed aokp 4.2 with the new gapps. I'm aware of all your sd data being moved to the /0 folder, but I still cant seem to be able to recover my music.
    Pictures are in the gallery no problem. I have spotify and I had at least 15 gb of downloaded playlists. Now after the aokp flash, all my playlists are "undownloaded" but the space is still being used up. Also, I cannot activate the photosphere feature. Can someone help
    - - - Updated - - -
    Pictures are in the gallery no problem. I have spotify and I had at least 15 gb of downloaded playlists. Now after the aokp flash, all my playlists are "undownloaded" but the space is still being used up. Also, I cannot activate the photosphere feature. I wanted to restore using my nandroid backup, but now I cannot locate the nandroid backup. Can someone help?
  14. #1564
    /data/media/0
    Is it there?
  15. #1565
    RJV3's Avatar
    Posts
    Global Posts
    174 Global Posts
    I see three folders
    legacy
    obb
    I'm not really liking how 4.2 totally did a number on the sd card. I go into recovery and into sd card/0/0/clockworkmod/backup and there file for my nandroid is there, but when I select the file, cwm says no files found
    - - - Updated - - -
    I see three folders
    legacy
    obb
  16. #1566
    I used TWRP. had CWM been updated for 4.2?
  17. #1567
    Why'd these get taken down?
  18. #1568
    The 1128 gapps were messed up. It failed to sync my bookmarks. I've seen several complaints in other threads
  19. #1569
    So what's a good gapps to flash?
  20. #1570
    RJV3's Avatar
    Posts
    Global Posts
    174 Global Posts
    Think I'm just going to go back to deoxed 4.1.1 since I'm having issues with 4.2.
    It was sweet while it lasted.
  21. #1571
    ConTejas's Avatar
    Posts
    ROM
    Quote Originally Posted by RJV3 View Post
    Everyone I've seen with the /0 (sometime mulitples /0/0/0/0 etc) issues have been on CWM, including the newest version that was supposedly updated for 4.2. Flash TWRP and you will not have any issues. The easiet way is from the goomanager app.(menu>intstall openrecoveryscript). It will automatically replace CWM with TWRP as your recovery. If you use Rom Manager, as I do only to save my buttons to reboot into recovery, you will still have the clockworkmod folder even after deleting it and its files. Doesn't matter though. Seriously, I like CWM and kept it until I had a reason to switch, but TWRP is just so much better across the board. It's not just hype.
  22. #1572
    Posts
    Global Posts
    397 Global Posts
    ROM
    I politely beg to differ. I flashed the latest TWRP in anticipation of switching to 4.2 to avoid the folder issues and potential loss of data, and I lost everything I had. I accept the risk of flashing anything, since that is the way it goes. Plus a clean start is always good! I guess the key is to back up anything critical or that you may want to keep to a computer, not your phone.
  23. #1573
    ConTejas's Avatar
    Posts
    ROM
    Well, that's an entirely different "zero" issue, isn't it Seriously, though, that stinks. Sorry to hear. What did you do? I don't see how flashing a recovery would wipe your sd card. Stranger things have happened. I wouldn't ward anyone off of TWRP because of this, though, it seems like a strange occurance. Not that that makes any difference to you Definitely good advice to backup to a computer. Another option is to use the cloud. I have everything important backed up on dropbox. No computer needed.
  24. #1574
    Posts
    Global Posts
    397 Global Posts
    ROM
    I have used TWRP since day one. I have no idea what wiped my sd card. Took all the usual clean install steps, rebooted and had nothing!
    Like I said, a clean slate is good I just wasn't expecting it. I wouldn't turn anyone off of TWRP either, much easier to use than CWM.
    Thanked by:
  25. #1575
    ConTejas's Avatar
    Posts
    ROM
    Loving skanks 11/30 build. Nav targets long press are awesome(were on atc's 11/27 too...but this is 4.2.1). No longer miss my lock screen targets.
    [ROM] Android Open Kang Project- Jelly Bean Style-uploadfromtaptalk1354305303123.jpg
    davey11 likes this.
Tags for this Thread
