08-25-2013 02:45 PM
1,915 ... 6263646566 ...
tools
  1. RJV3's Avatar
    Thank you all for your candid feedback.
    As of today I was set on the fact that I was going to lose my data regardless.....now here the weird part.
    i used the tool kit and the downloaded stock deoxed 4.1.1 vzw image and restored my phone. But i still saw the 0 sd card folder issue. and was down to 5GB of space left. I deleted all of the duplicate files and regained 15 GB, flask the 11-29 gapps, flashed tiny kernel, and then the latest 4.2 aokp rom.
    Most of my music was regained, and all of my wallpapers, photos, pictures, etc were right where they belonged. Ringtones, notifications, etc.
    I love the plethora of tweaks I can do on aokp. Just wished I didn't have such a hard time with the sd card.
    I did have to reinstall the 4.2 gallery / camera zip file since the stock one on the 11-29 gapps did not include the photosphere feature, but it had the new gallery and camera.
    Weird?
    If anyone is using tiny's kernel, what governor are you using? I saw on the other forums interactive is not so great on this rom.
    11-30-2012 01:55 PM
  2. 10001110101's Avatar
    Weird?
    When you say duplicate files, which ones are you referring to? I lost everything as well, and I wouldn't mind getting it back.
    11-30-2012 01:59 PM
  3. 10001110101's Avatar
    Never mind. I found all my missing stuff! It was at the root/data location.
    ConTejas likes this.
    11-30-2012 02:12 PM
  4. bbudnick5001's Avatar
    I think generally people flash the ROM then gapps and then kernel(kernel for me being after I set up the phone). You may have had a problem with the camera because you flashed the ROM last but I am not sure.
    11-30-2012 02:48 PM
  5. RJV3's Avatar
    In the order of flashing
    aokp 4.2
    then gapps
    then kernel.
    Of course this is all done after factory reset / user data wipe, wipe cache, wipe dalvik cache. So far so good with aokp and loving this rom.
    bbudnick5001 likes this.
    11-30-2012 03:01 PM
  6. bbudnick5001's Avatar
    Cool
    11-30-2012 03:13 PM
  7. Jubakuba's Avatar
    Bye bye.
    11-30-2012 03:31 PM
  8. ConTejas's Avatar
    aokp 4.2
    then gapps
    then kernel.
    Just wanted to add that you should also format or wipe system when flashing a rom. More of a precaution but it only take a few seconds. So factory reset/wipe data, cache, dalvik, system...then flash rom/gapps
    11-30-2012 03:38 PM
  9. j.glik14's Avatar
    Where did you get this build from? As well as gapps. I feel clueless haha
    11-30-2012 06:28 PM
  10. Jubakuba's Avatar
    Compiled from source.
    Gapps...I'm sure you can find some.
    11-30-2012 07:13 PM
  11. jova33's Avatar
    Juba, do you compile for grouper?
    Sent from my wireless telephonic device.
    Jubakuba likes this.
    11-30-2012 09:22 PM
  12. Jubakuba's Avatar
    I have an n7, so yes.
    I accidentally deleted the most recent in my folder...and haven't built for it in a couple days.
    Maybe I'll drop one in the grouper thread this weekend.
    11-30-2012 10:03 PM
  13. jova33's Avatar
    I didn't even see a grouper thread for AOKP?
    11-30-2012 10:10 PM
  14. Empty Hand's Avatar
    Bye bye.
    I feel like I missed something.... I guess I need to check here more often.
    12-01-2012 10:42 AM
  15. jova33's Avatar
    Juba posted a build. I'm on euroskank's Nov 30 and it's running fine.
    JkdJedi and ConTejas like this.
    12-01-2012 10:59 AM
  16. ConTejas's Avatar
    +1. 2 days of butter
    12-02-2012 01:50 AM
  17. Jubakuba's Avatar
    asfdasdf
    12-02-2012 02:40 AM
  18. j.glik14's Avatar
    flashed the link above and just screwed myself over being a dumbass. i have no backups and no romson my phone because i wiped before flashing. i flashed the wrong gapps with the rom and basically now i have no rom on my phone. what do i do?
    12-02-2012 09:30 AM
  19. Jubakuba's Avatar
    See my sig.
    Part 1 for adb
    Part 3 to adb push rom.
    12-02-2012 09:52 AM
  20. j.glik14's Avatar
    Got up. Thanks. Works grrat
    12-02-2012 10:33 AM
  21. CallerHoller's Avatar
    What's grouper?
    12-02-2012 07:16 PM
  22. zero neck's Avatar
    What's grouper?
    nexus 7
    12-02-2012 07:21 PM
  23. Explicit's Avatar
    Anyone else having the web browser close out while looking up different pages? Don't know if it's an issue with M1 or not. It just started happening over the weekend
    12-03-2012 02:50 PM
  24. ConTejas's Avatar
    No issues on *****'s 12/2 build. Try clearing the browser caches.
    12-03-2012 02:58 PM
  25. bbudnick5001's Avatar
    Maybe too many tabs opened up?
    12-03-2012 03:25 PM
