Page 72 of 77 FirstFirst ... 69707172737475 ... LastLast
Results 1,776 to 1,800 of 1915
Like Tree420Likes
  1. #1776
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    Yeah build 3 is not stable on the Verizon Galaxy Nexus. I went back to build 2 and it works great. Curious about the 4.2.2 build. I'll wait till they have an official one though.
  2. #1777
    Quote Originally Posted by bj1126 View Post
    Adam's 4.2.2 build is running great. Much better than build 3.
    AZDROIDX and oxymoron like this.
  3. #1778
    What all is 4.2.2 supposed to fix. I've seen that a bluetooth issue is fixed.
  4. #1779
    Canuckfan's Avatar
    Posts
    ROM
    CM10 JellyBro | Franco M5
    Quote Originally Posted by Empty Hand View Post
    +1. Didn't try build3 but running Adam's latest build and everything is running pretty smoothly.
    oxymoron likes this.
  5. #1780
    AZDROIDX's Avatar
    Posts
    ROM
    Bugless Beast- GNex
    What build does Adam do? I've had issues when I went from DizzyAOKP to Build 3 of AOKP and my wife went from Build 2 to 3 and has had sluggish issues too. Thanks.
  6. #1781
    Quote Originally Posted by AZDROIDX View Post
    A lot of the team members build "unofficial" builds in between official AOKP builds. Since the only device I have is a toro gnex, that is all I keep up with. Adam put out the build referred to above last week, sethyx put out a build over the weekend, and zaphod put out a build today. The best place to keep up on the builds is rootzwiki. I usually just flash the newest as they are released.
    Thanked by:
  7. #1782
    Explicit's Avatar
    Posts
    Global Posts
    269 Global Posts
    ROM
    AOKPJBM1 | JameBond 3.4.6
    JB-MR1 Build 4 is out. 4.2.2 is merged in this build
    Thanked by:
    Hondo_Lane likes this.
  8. #1783
    Canuckfan's Avatar
    Posts
    ROM
    Quote Originally Posted by Explicit View Post
    Toro build is now out:
    Thanked by:
  9. #1784
    Damn, wish I would've seen this before I turned off my phone for the night. v_v Ah well, gives me something to do first thing tomorrow morning!
  10. #1785
    Is it sluggish like bld3?
  11. #1786
    Explicit's Avatar
    Posts
    Global Posts
    269 Global Posts
    ROM
    Quote Originally Posted by CallerHoller View Post
    That's exactly why I'm waiting. Didn't flash B3 to my phone for that reason and hoping it isn't an issue in B4.
  12. #1787
    I'll give it a shot tomorrow night. Report was that the 4.2.2 build was solid so if it is merged here it should be good to go. That's what backups are for!
  13. #1788
    Of course it's "merged here."
    Source doesn't work backwards (unless huge mistakes are made and reverts come in to play).
    Once 4.2.2 was merged like...a week ago?
    It's stayed and will stay 4.2.2.
  14. #1789
    I feel like my battery life is slightly better on this new build. Been off the charger for a couple hours, now, and though it's mostly been asleep, I've only lost about five percent. Usually, it's closer to double that.
  15. #1790
    Foyt20's Avatar
    Posts
    Global Posts
    173 Global Posts
    Seems solid after 12 hours. Absolutely no problem with Bluetooth. I can't speak to battery life, have had it on the charger for 90% of the time it has been installed. Will update when I have an answer.
    Oh, and 4.2.2 is awesome.
  16. #1791
    I just went to build 4. Must have done something wrong as i'm getting continuous System UI crash notification...
  17. #1792
    Foyt20's Avatar
    Posts
    Global Posts
    173 Global Posts
    Do a full wipe and try again?
  18. #1793
    Hondo_Lane's Avatar
    Posts
    ROM
    AOKP M2
    Hmmnnn... well that didn't go too well. When I flashed this it just seemed really sluggish... press on something and wait several seconds before it responds. I haven't seen anything like this since my original droid days. Used TWRP (full wipe)/ MyBackup Pro / Nova Prime... which is my standard deal and I usually never have an issue. I finally flashed my backup and got out of there.
    I might try to load this on my N7 tonight and see how it does...
  19. #1794
    Hondo_Lane's Avatar
    Posts
    ROM
    AOKP M2
    Quote Originally Posted by Hondo_Lane View Post
    On a brighter note, I had never flashed a nandroid so I didn't really know what to expect. Perfect restore down to every detail... 's like magic ya know!? lol
  20. #1795
    SeigaGen's Avatar
    Posts
    ROM
    Kang/CM10
    Folks at AOKP have acknowledged a Bluetooth issue with the latest AOSP 4.2.2. The issue is that the range has been cut down to 10ft when before it was significantly longer. Sound quality from the Bluetooth has improved immensely. They and I'm sure many folks are trying to find a way to resolve this issue.
    1. There's no AOKP-wide GPS issue. It's working great for a lot of us. Please re-flash (clean), and try it again. Also, if you're restoring Maps from backup, don't restore data. That will frequently cause issues (not necessarily GPS issues, but issues are bad regardless). Also, make sure you're outside, or very close to a window. I know that on my device at least, if I'm not outside, there's only a small chance of getting sufficient satellite locks for it to pinpoint my location. Also, my device is crap when I'm in a heavily wooded area like my local parks. I don't know if it's the same for everyone, but I'm assuming so (I could be wrong though, who knows).
    2. Wakelocks from Maps happen frequently. A couple things to try, go into Maps, then Settings, then Location Settings. Disable everything in there. All of those settings are for Latitude, and should have zero effect on Maps or Navigation. Also, go outside, start up Maps, and wait for it to say Location Set By GPS. Then back out of Maps. You shouldn't see excessive wakelocks afterwards.
    3. Bluetooth connection (not necessarily playback quality) issues...yes, it's real, stop posting about it please. Zaph is aware of it, and I'm assuming other dev's are as well. Until someone posts something saying it's fixed in whatever change and that it should be included in the next release, please assume they're working on it. If it's absolutely critical to you, please go back to a 4.2.1 or 4.1.x release until it's fixed, nobody will be offended.
    4. If you didn't clean flash, and you're having issues...too bad. Sorry, but it's always recommended to do a clean flash. If you can't, and you do a dirty flash and start having random issues, you brought it upon yourself. If you dirty flash and everything works great, good for you. However, please don't tell people "hey, it works just fine" unless if you want them to contact you directly for any issues they have resulting from the dirty flash. We all have different setups, and any one little piece of old data can cause bootloops or FC's. The thread really doesn't need to be clogged up with people asking for help with issues they brought upon themselves by not following the directions.
    Sorry...after a dozen pages of people talking about the same issues over and over, it just gets a bit annoying. Maybe I need a vacation...
    Motorola Droid Maxx
    Samsung Galaxy Nexus - RIP
    CM10 Jellybro Jelly Bean
    Asus Nexus 7
    AOKP JB Milestone 1
  21. #1796
    Yeah, ended up doing that and it did the trick.
  22. #1797
    That guy is not an official AOKP voice...
    But yes, Bluetooth confirmed.
  23. #1798
    lordbah's Avatar
    Posts
    Global Posts
    424 Global Posts
    Not sure this belongs here but the upgrade is one thing I did when the problem occurred ... had AOKP build 1 running, Nova Launcher, saved Nova settings, TiBu backup, did a factory reset and installed build 4, TiBu restore, restore Nova settings ... and all icons on the home screens are the green robot (in the 'all apps' view the icons are fine). Nova problem or AOKP? How can I correct it?
  24. #1799
    Xanth269's Avatar
    Posts
    Global Posts
    452 Global Posts
    ROM
    AOKP Build5
    Quote Originally Posted by lordbah View Post
    Just a thought, when you did the all apps (I would guess the middle button on home screen) did you try and open the app? sometime I find I have to reinstall the app despite the icon appearing in the apps pages and not on the home screen(s). When you go to the app store, I use my apps and reinstall what I want.need. let us know, looking to do the upgrade to build 4 from the milestone 1 build, be holding off on 4.2 builds.
  25. #1800
    lordbah's Avatar
    Posts
    Global Posts
    424 Global Posts
    Yes. Opening the app did not restore the icon to the home screen. The app can be launched from the bad icon on the home screen, it's only the graphic which is wrong.
    I was only trying nova because it had a way to save/restore my home screen layout, whereas with the default launcher I had to redo everything every time I did a clean flash. If it can't restore icons for some reason I'll just ditch it.
Tags for this Thread
B
