Page 8 of 76 FirstFirst ... 567891011 ... LastLast
Results 176 to 200 of 1896
Like Tree419Likes
  1. #176
    chubb's Avatar
    Posts
    ROM
    Stock Xoom, Nexus 4 AOKP
    Default
    Quote Originally Posted by dmmarck View Post
    Oh wow. Yeah wait for your computer lol
    Its a loooonnnnnggggg one! By the time I get it though preview 6 or 8 will be out. Maybe 1.0
  2. #177
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default Re: [ROM] Android Open Kang Project- Jelly Bean Style
    so got the P4 file and on the first page it says to use gapps jb-2012-01-17-signed
    In think in the thread I saw a new gapps aokp-gapps-07 .
    does it matter which one I flash?
    thanks,
    Xanth
  3. #178
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Wipe system as well! If you do data, cache, dalvik, system, in that order it's clockwise .
    Ok so I got TWRP installed and rebooted and checked it out, still only have done a back up with it..
    following the clockwise order I do not see data on top to make a clockwise rotation, unless you mean format data, cache, dalvik and then system. <-- guidance please...
    wipe screen:
    Cache ******* Dalvik
    Factory Reset ******* System
    blank space ******* Internal Stoage
    Format Data ******* blank space
    As always THANKS! : )
  4. #179
    Poseign's Avatar
    Mobile Enthusiast
    Posts
    Global Posts
    601 Global Posts
    ROM
    AOKP JB B1/Franco M5
    Factory Reset > Cache > Dalvik > System in that order. No need to format data. After you flash your new ROM and GAPPS it's becoming a habbit for me to hit "fix permissions" as well.
    Ideally you want to use the GAPPS that the ROM description tells you to use, but if theres a newer one linked you should be fine to use it. Think back to this first though if you have any issues after the flash.
  5. #180
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    Quote Originally Posted by Poseign View Post
    You do NOT have to fix permissions. Since gingerbread its not necessary and can cause more harm than good. Any dev who tells you you need to is not worth a lick... Or maybe is giving you some weirdly experimental stuff to flash, idk.
    Just words of wisdom everything else Poseign mentioned is solid.
    Thanked by 2:
  6. #181
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Ok so I followed the instructions all is loaded. I hate downloading the apps, thankfull I have NOVA. I was going through some of the apps I use, I tried the GPS, I get no audio, I went into
    Text-to Speech Output and tapped listen to an example, nothing. Known issue with AOKP? or like in Jakes JB there was a file to install for this to work?
    Also in the pull down toggle what is the "pink icon"?
    And when I do a about phone AOKP version shows aokp_toro_jb1, but I downloaded 4 from the link on page 1.
    EDIT: OK same issue as with JB missing file - Found answer on RW: Worked for me!
    Fix for the Text To Speech issue
    Put a copy of libpatts_engine_jni_api.so in your System/Lib folder.
    I grabbed that file from the 2.6 ROM. Here is a link to it in my drop box:
    Credit to Scripting Samurai fpr posting and Vek_ in IRC for discovering the missing file.
    Thanks,
    Xanth
    Thanked by 2:
  7. #182
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Xanth - the link is busted, mine reposting?
    Actually, I have that file, but just for anyone else .
    Some custom made boot animations, BTW:
    Black/white ==>
    Color ==>
    Place the file in either system/media or data/local.
    Thanked by 2:
  8. #183
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    From RW
    (its about 1/2 way down the page)
    for some reason I can not copy the link and paste, it always fails... sorry dont know any other way to do this, I dont have a dropbox to figure it out yet but I guess its time.
    Hope this works
    Thanked by 2:
  9. #184
    Default
    Steve Spear of the AOKP team posted on RootzWiki about a new test build. It's not being called "preview 5" yet, but I think it will be. Here is a link to his test site. Obviously, the one with a modification date of today is the one to grab (build 1 in the name). Seems like a good place to check for other updates in the coming days. As Steve said, this is his personal test build site. Nothing official about it. Happy flashing!
    Thanked by:
    cadman
  10. #185
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by Empty Hand View Post
    I saw it on RW but I didn't see where he discussed it. Do you have a link to that?
    Edit: NM, found it.
    Also, I flashed this a few minutes ago along with a new boot animation. I'm digging it .
    Thanked by:
  11. #186
    Default
    Edit: NM, found it.
    I just flashed the new boot animation. Pretty sweet!
  12. #187
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Default
    Did you do the colored multi geared one?
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
  13. #188
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    Black/white ==>
    Color ==>
    So do you flash these in recovery? Would like to try them.
  14. #189
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by Xanth269 View Post
    I don't believe they are flashable unless they state as such. Just do what I described--move them. If you check out the links though, there are other, new ones, and there are flashable versions.
  15. #190
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    So quick question. Flashed preview 4 today took a real long time to boot saw that crazy uni for what seemed forever. Anyone else with a longggggg book or is there a setting to speed it up.
  16. #191
    Default
    Wow just flashed jb aokp and I need some radios badly... help plz
  17. #192
    Canuckfan's Avatar
    Posts
    ROM
    CM10 JellyBro | Franco M5
    Did you happen to dirty flash to P4? If so, please read this post from RW explaining the reason for long boots. It has something to do with a new file system check introduced to the boot sequence in JB.
    Thanked by:
  18. #193
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    DM, do I have to rename the existing boot animation file? I copied the file and it added copy to the file name.
    Thanks!
  19. #194
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Thanks!
    Make sure it is named:
    bootanimation.zip
  20. #195
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default
    Yes there is on with a date of Aug 1 2008 and the one I just d/led with July 26, 2012 that also has the word copy in the file name.
  21. #196
    Running Preview 4 today, and I can watch the battery drain like it's being sucked through a straw. =/
    Anybody know if it's the kernel that comes with AOKP p4? Or can recommend a better one? I didn't see any mention of which kernel it's packaged with.
    "Some see the glass as half-empty, some see the glass as half-full. I see the glass as too big."
    - George Carlin
  22. #197
    watchtheflames's Avatar
    Posts
    ROM
    Liquidsmooth 1.25
    Quote Originally Posted by DenverRalphy View Post
    Francos is working great for me. Just get his app.
  23. #198
    Explicit's Avatar
    Posts
    Global Posts
    246 Global Posts
    ROM
    AOKPJBM1 | JameBond 3.4.6
    Been reading the 4.1.x kernels are working good with the AOKP JB previews
    Thanked by:
    JkdJedi likes this.
  24. #199
    killroy420's Avatar
    Posts
    ROM
    AOKP / Franco Kernel
    Default
    Same here. I am running P4 with Franco r224 and getting reasonable battery life.later about 8 hours, with 4 streaming YouTube and 2 streaming podcasts over 4g with Max brightness settings on the screen
    I am however looking forward to seeing some updates as I have experienced some (in my opinion)big bugs like random reboots, poor GPS locks and wonky 4g/3g switching and this weird problem with my contact phone numbers being truncated and profile pics not showing. Oh well...only problem with being on the bleeding edge is sometimes you gotta bleed :o
    I tried to think of something witty, but this is all I could come up with.
  25. #200
    Default
    My last 5+ hours. To be fair though, the first 3 hours I was working in the equivalent of an underground bunker without Wifi access, so the radio/power negotiations had to be horrible.
    Attached Thumbnails Attached Thumbnails [ROM] Android Open Kang Project- Jelly Bean Style-uploadfromtaptalk1343358530413.jpg
