2defmouze
So in TWRP wiping dalvik/cache/system doesn't wipe data? Does "factory wipe" = data wipe? Didn't want to empty the SD partition.
Maybe it has been too long since I flashed anything new. But thanks to AOKP for the new ROM.
In both TWRP and CWM if you don't do "Wipe data/Factory reset" you are dirty flashing... the sdcard partition does NOT get wiped by either custom recovery when you do this though. Yeah you're just out of practice
