Has any of Steve's work (specifically the Linaro optimizations) been merged with the latest MR1-Build 2 release?Steve's latest PUB build is blazing fast. It's got its own thread over on rootz: Stevespear PUB AOKP builds - Project Unicorn Butter - AOKP - RootzWiki
Has anyone else noticed an issue in which the stock keyboard no longer automatically corrects typing just "i" to the capital "I"? It used to correct to "I" for me when I was using the DizzyThermal 4.2 nightly builds, then at some point, it stopped correcting to the capitalized version. I did a full wipe when I flashed to the official AOKP MR1 release, and it still doesn't autocorrect to "I". Kind of annoying, especially considering I do a lot of typing on my phone.
MR1-Build 2 fixed this issue, for me at least
Are you using the stock Kernel, MRW? If not, just reflash whatever kernel you have (like Franco or something) and the stock settings for that kernel should populate. In general, I run interactive governer with stock 1228 speed.
I dirty flashed and has the same problem. Killed my battery like crazy, Gonna clean flash and see what happensInteresting bug I found on mr1.2... guess that's what I get for dirty flashing from mr1.1
What, exactly, is the bug? I don't understand just from seeing that screenshot. I dirty flashed from build 1 to build 2, and I haven't had any issues, though I never use bluetooth, so... Anyway, my battery life has seemed quite a bit better since flashing to build 2. I'm kind of impressed, unless that was just an unusual phenomenon yesterday.
Ah, okay. I use Franco kernels (off topic, but anyone know why there hasn't been a new nightly since 361? Seems like they were coming out pretty regularly, but it feels like it's been a while), and I was able to get things back to normal just by resetting the power mode I had on via the Franco app.
