MRW1215
Not happening.
Ah. Is there a reason for that, or just no interest?
Not happening.
We have hiding navbar.Ah. Is there a reason for that, or just no interest?
I flashed the 3/31 build before he put up 4/1 and was like, "WTF is up with my thumbnails?" LolLooks good, I'll be flashing akellars ROM tonight.
Flashing now. Anything new at all?
Clean Flash.Trying to flash milestone, but I keep getting an error saying "unfortunately AOSP keyboard has stopped working" I've redownloaded the rom a couple of times and tried a new flash, but each time it pops up with the same error. I've redownloaded my Gapps package (Gapps 20130301) still can't figure out why I am getting this. If I flash back to build 5 then the error goes away. I've tried to go into settings and clear data from the keyboard and the dictionary (cant find this one). I'm lost, anyone experience this before?
Are you, by chance, hitting both volume buttons and power by accident?I am running the new milestone, and I'm getting a vibration every time I'm on the home screen that causes it to open up Gmail to send a bug report. I'm not sure what is causing it, nothing seems to be crashing
No.It could be the launcher. Are you using the ROMs launcher or an alternative? I use Nova so I haven't had your glitch. It might be an app or widget FC in the back ground. The only thing I can think to trouble shoot is to uninstall things that are running and see what still causes error.
