Results 1 to 2 of 2
- 07-23-2012, 08:16 PM
Thread Author #1
GPS Issues-Droidvicious Jelly Bean 4.1.1 V1
Hey all!
A couple weeks ago I flashed the lastest version of DroidVicious Jelly Bean 4.1.1 V1 to my Verizon GNex. Recently noticed that the GPS isnt working. Before I rooted my phone at all, the GPS was perfect. Now, it just gets stuck on "Searching for GPS" whenever I try to navigate somewhere. It correctly finds my location but will not be able to navigate me to the place I want to go. Any known issues/fixes with this?
p.s. Yes, all location services are enabled
Thanks! James. - 07-23-2012, 08:25 PM #2
You are on a very outdated version of a ported ROM.. You should update as now basically all ROMs are based on AOSP. I'd recommend Bugless Beast or one of the CM10 Kangs available. Check dmmarck's Jellybean thread for info and links.
Reply
