1. acard811's Avatar
    All of a sudden my phone won't take a charge or be recognized by my computer so I thought OK no big deal I have insurance, I'll use my insurance. Unfortunately I'm rooted and romed and have no idea how to he back to stock and lock without my comp :/ help!
    07-26-2012 07:29 PM
  2. zero neck's Avatar
    have you tried using different usb cords and different usb ports?
    that's first.
    if you have a backup that working well, i would restore it and try that also. or a rom that was working well before - you can do a clean install of it.
    if neither of those pan out, we can see what we can do for ya.
    acard811 likes this.
    07-26-2012 07:33 PM
  3. acard811's Avatar
    OK tried a bunch of cables and adapters to no avail. Restored backup, I believe it should be stock but I've attached the about phone If you can verify. Where can I go from here to relock?
    P.s. thank you so much!
    zero neck likes this.
    07-26-2012 08:07 PM
  4. acard811's Avatar
    I finally got it to connect after doing the restore, thanks for the help. I was able to run Wug's to reflash stock and unroot, as well as relock. But the weird thing is that after i went through all that my phone still had the jelly bean background when it booted back up. Anyway thanks for the help I really appreciate it!
    07-26-2012 08:48 PM
  5. zero neck's Avatar
    Awesome , the wallpaper you mean? Prolly backed up thru gmail
    07-26-2012 10:20 PM
