Ok, so I'm a Root virgin, and am finally ready to take the plunge with my VZW Galaxy Nexus. Since this is my first attempt at root, ever, I was very excited when I came across Wug's simplified toolkit for easy root for my Verizon Galaxy Nexus, here on this site (originally posted back in January) and I started to attempt to use the program on Windows and am doing the Initial Setup to Install the Drivers. I am running Windows XP and have followed all the steps, however, I keep running into problems installing the drivers. My device automatically configures as an ADB device, however, when I skip to step 4 and List ADB Devices, I do not get a serial number (which the program says you will if its done correctly), only a dialogue that says No ADB devices found. I have repeated steps 1-3 over and over again, and have even manually chosen drivers, with the same outcome. Any suggestions or thoughts on how to remedy this? Also, if there's a simple way to accomplish Root using a Mac, those instructions are welcome too. Thanks!
