Results 1 to 6 of 6
- 08-04-2012, 02:51 PM
Thread Author #1
Trinity problem
Trinity's option to adjust the display color and adjustable vibration are grayed out on my phone (meaning I can't click on the options). I did a clean wipe. I'm running trinity version: TNP1536-307-JB-STABLE35.
I'm stumped.
I attached screen shots.Last edited by Keekers11; 08-04-2012 at 03:54 PM.
- 08-05-2012, 08:19 AM #2
Re: Trinity problem
That will happen. Those options are baked into the ROM for the kernel that has been placed with the ROM. If you want to tweak the color settings you will need to download the trinity toolbox from the market place (). It is a worthy investment and makes it super easy to flash the newest kernels. In there you can tweak MUCH more than what you get from your ROM.
[GUIDE] Unlock Your Note 2 Bootloader! | [ROM] AOKP Jelly Bean for Verizon GS3
[GUIDE] VZW ROM Listing and Guide | [GUIDE] VZW Galaxy S3 Flashing Guide
[GUIDE]Freezing GS3 Bloat with Titanium Backup! | [GUIDE] Restore Back to Clean Factory Stock Updated 9/22
[GUIDE] [MODEMS] VZW SGS3 (SCH-i535) | [ROM] Official CM10 Nightlies on your GS3! - 08-05-2012, 09:03 AM #3
OP, which rom are you running?
When I was running AOKP a few days last week, all of the options were available.
When I went back to Euroskank, the vibration settings are deselected now. I am going to flash back to Trinity kernel shortly and see if I get what you are seeing. I do recall not having a whole lot of options before using AOKP though. I was probably using trinity at the time as well.
Sent from my Galaxy Nexus using Tapatalk - 08-05-2012, 01:41 PM
Thread Author #4
- 08-05-2012, 03:57 PM #5
Alright... So AOKP with stock kernel shows all settings available. Euroskank stock kernel showing some, but not all settings available. Euroskank with trinity kernel only shows color hack presets available to change.
I thought I read somewhere that Euroskank is now using Franco kernel as its default. That's probably why you are seeing less options available.
Sent from my Galaxy Nexus using Tapatalk - 08-05-2012, 04:18 PM
Thread Author #6
Reply
