Results 1 to 6 of 6
Like Tree3Likes
  • 3 Post By bbudnick5001
    Default Please help... first time rooter...
    I am following the seemingly easy directions to root the device, and everything seems to go well... however, when I put in the final command on the command prompt "fastboot-windows oem unlock" i just get a message that says "waiting for device."
    I can't figure out the issue and I can't find a solid answer that I understand online. Can anyone help???
    Thanks!
  2. #2
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default
    It's a driver issue.. Check the troubleshooting section of the unlock thread, you just need to update the drivers correctly.
    Thanked by:
    Default Re: Please help... first time rooter...
    Awesome got it.... I am now just waiting for the device to reboot!
    Final question: my main goal was to install Jelly Bean, and there are like 10,000 versions out there. Which one would be the most stock-like? Or which one is recommended as the most stable?
  4. #4
    bbudnick5001's Avatar
    Posts
    ROM
    AOKP/CM10/AXIOM ROMs
    Default
    Quote Originally Posted by estebancam View Post
    Currently everybody seems to be running AOKP nightlies or Euroskank Jellybro CM10 nightlies. Both seem to be pretty darn stable. Just make some nandroids, flash some ROMs and have fun. But, be aware crackflashing is very addictive !!!
    2defmouze, oxymoron and CA1NE like this.
  5. #5
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    If you want stock, run Bugless Beast .
  6. #6
    Default
    Quote Originally Posted by dmmarck View Post
    Or if you want stable and fast without "bloaty" options, run bugless :-)
    Nexus 4 / Stock | Nexus 7 / Stock | TFPrime / Hairy Bean 2.1.1
    @digitalslacker
    +digitalslacker
