- Aug 28, 2011
- 46
- 4
- 0
Not sure what I was thinking ...
Background:
I had noticed that my volume(-) down function had not been working. For example, I could not do screenshots with volume(-) + power. I also could not lower the volume using the volume(-); I had to volume(+) and then slide the volume down on the screen
Well, when I was flashing a new ROM (backup, wiped cache; dalvik and format/system), I could not find the new ROM. I believe I mistakenly saved it in a sub-folder on the sd card. No Biggie; I said, I will find it, delete it, or move it. However, instead of re-flashing an old ROM, or restoring a Backup, I simply Rebooting the Phone.
Well now, when I attempt to Boot into Recovery (battery out / volume down+up / power) I simply get the Google Lock Screen no matter how long hold it. I also cannot access the phone using the USB.
Is there a solution?
Background:
