Results 1 to 22 of 22
- 09-07-2012, 08:46 AM
Thread Author #1
[VZW][LTE] Google wallet build.prop
It seems as though Google keeps eliminating all the simple holes allowed you to install or update Google Wallet using the play store onto a VZW galaxy nexus.*
I got tired of it and modified my build.prop file like d2vzw owners are doing using root explorer to the GSM variant to trick the play store and allow me to install/update it.*
1.****** Made a nandroid backup
2.****** Reset google wallet from inside the app.* (I had wallet previously sideloaded and installed in /system/app )
3.****** Cleared the apps cache and data
4.****** Made a copy of the build.prop file in /system and renamed it to build.prop.bak
5.****** Using Root explorer I edited the build.prop file in /system to be as follows:
ro.product.name = yakju
ro.product.device = maguro
6.****** Restarted…and wala Google Wallet found the play store update and was auto-updating to the latest version by itself.
I’m rooted running Viscous-Toro-V1 (AOSP), WIFI/BT/GPS fix, FF02/FG02 radios from JRO03O.
Now my question since I’m not a genius. Since I’m rooted and ROM’ed and not going to be receiving any OTA update or anything what would be the harm in leaving the modified build.prop file active?* The d2 owners talk about reverting back to the original file but since I’m just switching from a LTE galaxy nexus build.prop to a GSM Galaxy Nexus build.prop I wouldn’t think but don't know if it’d do harm.
Sent from my Galaxy Nexus using Tapatalk 2 - 09-09-2012, 08:43 AM #2
Re: [VZW][LTE] Google wallet build.prop
>> but since I’m just switching from a LTE galaxy nexus build.prop to >> a GSM Galaxy Nexus build.prop I wouldn’t think but don't
I was wondering the same thing. I'm going to try it and see. I'll report back if it blows up. - 09-10-2012, 08:13 AM
Thread Author #3
I haven't had any issues yet.
I read that if you modified your build file to get svoice one will quit working. You can't have both and its either one or the other.
I don't have svoice though so its not an issue for me.
Sent from my Galaxy Nexus using Tapatalk 2 - 09-13-2012, 10:11 PM #4
- 09-14-2012, 01:18 AM #5
- 09-14-2012, 08:03 AM
Thread Author #6
- 09-14-2012, 07:11 PM #7
- 09-16-2012, 07:22 AM #8
Is there a reason you edited the build.prop files to what you did?
Sorry, completely new to this and wanting to root my phone.
Sent from my Galaxy Nexus using Tapatalk 2 - 09-16-2012, 01:50 PM #9
- 09-16-2012, 03:57 PM #10
It fools everything you load too so be careful with that, I was updating my recovery (TWRP) and it was about to load the GSM version of it, I really don't know what might have come about that if I didn't catch it. (should i try it)?
Anyway, I side loaded the CDMA recovery instead, just a FYI.
- 09-16-2012, 04:24 PM #11
- 09-19-2012, 09:35 AM
Thread Author #12
- 10-04-2012, 02:24 AM #13
- 10-04-2012, 11:32 AM #14
This isn't working fo rme. It will allow me to find and install it form the market, but it still gives me the message saying it isn't yet available for my device... :/
EDT: scratch that.. it worked after clearing data on Wallet...which is odd being I didn't have it installed before (just flashed a stock factory JB image)Last edited by Cory S; 10-04-2012 at 11:54 AM.
- 10-04-2012, 12:03 PM #15
While this IS cool, it may lead some to believe sideloading the app is somehow more difficult than clicking a download link, opening your download folder, and installing it
If you're a fan of auto install, great. I've had enough auto installed app "updates" that completely ruined the app so I tend to read a review or two and make a decision. My 2 cents.
- 10-04-2012, 12:12 PM #16
- 10-04-2012, 12:14 PM #17
- 10-04-2012, 12:55 PM #18
- 10-04-2012, 04:32 PM #19
- 10-05-2012, 07:47 AM #20
- 10-08-2012, 08:24 PM #21
- 04-03-2013, 08:11 PM #22
OK this was genius, worked like a charm and made me feel so much safer than loading someone elses app that then looks at my credit card numbers. THANKS A LOT.
Reply
![[VZW][LTE] Google wallet build.prop-snap-yo.jpg](http://forums.androidcentral.com/attachments/verizon-galaxy-nexus-rooting-roms-hacks/39779d1349386365t-vzw-lte-google-wallet-build-prop-snap-yo.jpg)
