Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By 7stringer
    Default Which of you crack-flashers are going to try out the CM10 Monthly first?
    I'm looking to try something with more customization than the otherwise superb BB. And if I need to go first, which GAPPs should I use?
    Thanks!
  2. #2
    mrdunn's Avatar
    Posts
    Global Posts
    65 Global Posts
    Default Re: Which of you crack-flashers are going to try out the CM10 Monthly first?
    Quote Originally Posted by ottscay View Post
    Thanks!
    If you want customization with a great ROM in all ways, try JBSourcery Version 2.2. The toolbox has almost an infinite number of whatever you want. I use the Steamworks Theme with many modifications and there are many other themes and mods.
    Which of you crack-flashers are going to try out the CM10 Monthly first?-screenshot_2012-09-11-09-20-52.jpgWhich of you crack-flashers are going to try out the CM10 Monthly first?-screenshot_2012-09-11-09-21-38.jpg
  3. #3
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    Quote Originally Posted by mrdunn View Post
ID:	37127Click image for larger version.
    That's a really cool theme.
    Doesn't the toolbox just download themes you could find on your own? If it's theming OP wants, AOKP and CM10 can offer that. Just about any ROM can be themed.
    “There’s always something to look at if you open your eyes!”
    -The Doctor-
  4. #4
    mrdunn's Avatar
    Posts
    Global Posts
    65 Global Posts
    Quote Originally Posted by Xfanatic View Post
    Much more options than themes and they have unique themes. They have a cloud toolbox that allows you to change just about anything easily, not just themes ie: any car or sport icon for the lockscreen button, any kind of weather, pulldown toggles, status bar, softkeys- hundreds of kinds, make anything any color you want, my softkeys are one of many kinds, changed to a gold color of my choice, all done easily and instantly. Example also include change battery, status bar, lkockscreen glow dots, lockscreen circles,. The also push notifications with every update or message. Follow the Magic Hat..... The main difference is that they do all the work, you just choose what you want, and the Magic Hat does all the work. I am not part of the team, I just like their work. And I am not a "CrackFlasher".
    And if you don't like what they offer, you can use T-Mobile Theme Engine. Check it out:.
  5. #5
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    It does look intriguing. Maybe it will satisfy my need for something new... At least a little longer. :-)
    Might have to give it a try.
    Allons-y
    -The Doctor-
    I wasn't asking about theming actually, I just wanted to give CM10 a shot now that the monthly was out as a first step beyond the mostly stock JB experience that BB has, so I was wondering if anyone else planned to give it a go.
  7. #7
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    I've been on it for ~4 hours at this point. Had a pain installing Swiftkey 3 (settings kept crashing), and I haven't had time to really do it up, but so far so good.
  8. #8
    mrdunn's Avatar
    Posts
    Global Posts
    65 Global Posts
    Allons-y
    I just noticed that the Rootwiki forum for the ROM has a picture of the ROM that cycles thru the various Toolbox options so you can really check it out. Just watch the OP for a few minutes as it cycles.
  9. #9
    7stringer's Avatar
    I have The Rickets
    Posts
    ROM
    Rooted and Ever-Changing
    Just flashed and getting setup. Comments forthcoming.
    Sent from my Nexus 7 using Xparent Cyan Tapatalk 2
    I wipe Dalvik in my sleep.
    Shameless self-promotion: my free music.
    www.soundclick.com/ericrose
    dmmarck likes this.
  10. #10
    kca2000's Avatar
    Posts
    ROM
    "Shiny" Stock Android
    Quote Originally Posted by dmmarck View Post
    Had this issue too, for anyone else having the issue this is how you get around it.
    Install swiift key (Uninstall/reinstall if you already tried the setup)
    Turn on swift key manually in the settings as well as making it the default.
    Run swiftkey setup wizard and it should skip the 2 steps everyone crashes on.
    Thanked by 2:
  11. #11
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by kca2000 View Post
    Must be a cm thing. Meh, oh well.
    Sent from my Overly Suspicious Robotic Grouper
  12. #12
    cyberdalek's Avatar
    Posts
    Global Posts
    366 Global Posts
    ROM
    Affinity/Franco
    I had the SwiftKey issue a few months back. I can't remember what I was running at the time but I never did get it figured out on that ROM. It might have been BB or ES.
    Also, I tried Sourcery and it is too busy for me. I am not into putting that much effort into setup. Nandroid back to Affinity.
    -The Doctor-
  13. #13
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Yeah it's minor. Others have confirmed its existence as well. Manual installation, like kca said, remedies the issue.
  14. #14
    Bears's Avatar
    Posts
    Global Posts
    168 Global Posts
    ROM
    AOKP JB5 w/ Franco Kernel
    Been on it for a few hours now. Runs great so far. I'm actually running it with Franco Kernel Milestone 5. No issues
  15. #15
    zero neck's Avatar
    The Ever-Living
    Posts
    ROM
    KANG
    I gotta say, I think aokp b1 still has this beat. Just my opinion tho.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  16. #16
    Froojr's Avatar
    Posts
    ROM
    Euroskank JellyBro/franco
    Did it manually, still wants me to do the second step, Enable Swiftkey, and stops if I click on it. The second step wants me to do it in the setup, but the third step is already done. Selected Swiftkey in settings, default set to Swiftkey.
    Make sure you do the manual setup in Settings before you ever open the Swiftkey setup! It'll work then.
  17. #17
    7stringer's Avatar
    I have The Rickets
    Posts
    ROM
    I'd fastboot install Swiftkey if I had to.
    I'm that dependent on it.
  18. #18
    bbudnick5001's Avatar
    Posts
    ROM
    AOKP/CM10/AXIOM ROMs
    I had an issue with trebuchet stopping and causing problems at random times. I fixed permissions from twrp and all is well since.
  19. #19
    Froojr's Avatar
    Posts
    ROM
    nvm
  20. #20
    flashed this rom Tuesday night - first ever custom rom installed. I'm relatively new at this, been unlocked for some time as i grew impatient with VZW's lack of updates (but they sure are quick to reply if you complain on twitter!). I enjoy the customization of this, but its lacking the buttery smoothness i got from the JRO03O update, and there are many more force close issues than I've experienced on any other stock release. I am, however, sort of addicted to this whole custom rom thing. I see people saying that BB doesn't offer much in the way of customization but that its great anyways, so what am i to expect when flashing it? and what others might you recommend to someone fresh on this scene? i'm done with cm10 until at least the RC builds.
  21. #21
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Quote Originally Posted by joeb3786 View Post
    Aokp
  1. Do you think we are going to get jelly bean?
    By Lavitapostandroid in forum AT&T Galaxy S II
    Last Post: 07-13-2012, 04:39 AM
  2. To those of you who have gotten Verizon to swap out for the Maxx
    By carracerz14 in forum Verizon Galaxy Nexus
    Last Post: 05-03-2012, 12:40 PM
  3. How many of you E4gT owners are looking to upgrade this year?
    By MannyZ28 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 04-28-2012, 10:43 AM
  4. FYI: If you are going to return your TB...
    By krazy in forum Verizon HTC Thunderbolt
    Last Post: 03-21-2011, 12:20 PM
  5. Are any of you guys using an app to speed up the shutter?
    By dr.duct_mossburg in forum Motorola Droid X
    Last Post: 08-03-2010, 11:11 AM
