This is my first post, so apologies if I'm in the wrong forum or am asking obnoxious n00b questions. I tried to follow a guide or app from start to finish, but since they often link to one another halfway through and I need to jump from guide to guide, I'm sure I got lost somewhere in there.
I had a Galaxy Nexus from Verizon that wasn't rooted or unlocked. I downloaded the Nexus Root Toolkit v1.5.3. I installed the full drivers under option 1, which seemed to install something called pdanet. I did some backups from inside that program, one with system apps & data, and one without. Then I unlocked the phone. Then I tried to root it and got stuck for a while, but after re-installing pdanet and so forth I was able to root the phone.
I started it up and, as instructed by the root toolkit, I hit a couple settings on superuser and fastbox or whatever that's called - I forget. Then I installed ROM manager and at the top hit flash clockwordmod recovery. Then I tried to install Cyanogenmod from within ROM manager. Everything was coming up roses until I got locked into the boot screen where a cyan man is surrounded by cyan waves indefinitely.
I tried to follow the instructions here : Troubleshooting - CyanogenMod Wiki but I can't get my phone into any other screen but 1) the Cyanogenmod bootloop screen, or 2) the one that has 'start' in a hollow green arrow up top, with a droid in the middle and text on the bottom. Once I get into Clockwork recovery mode, I can't mount the phone as USB or see it AT ALL in windows explorer, which seems to be the key to getting it working again.
Thanks. I know I'm a rookie at this type of thing, but lifehacker and many other sites have encouraged me to think of unlocking/rooting/flashing Cyanogenmod as a fairly accessible process. But I can't seem to find a comprehensive guide; I end up having to jump from so-called comprehensive guides to other so-called comprehensive guides, program to program, and I get lost in the meantime.
