Results 1 to 7 of 7
    Default How does it remember?
    So the last few ROMs I flashed seem to remember some settings (my WiFi password, notification light color) even though I have done a full wipe with TWRP. Am I not wiping right?
    But they don't remember ALL my settings (sleep timer, brightness, etc)
    Whats going on?
  2. #2
    bakerbert's Avatar
    Posts
    ROM
    JellyBeans
    Default Re: How does it remember?
    i have noticed that also;
    my guess is, that information is saved on the virtual SD card somewhere (SD Card info is not effected during a wipe)
    Sent Via..Raven from Kings Landing
    BB Storm 1 > Samsung Droid Charge > Samsung Galaxy Nexus > Samsung Galaxy Note II
  3. #3
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Certain things are backed up by your Google account. If you're concerned about wiping fully, a full wipe in TWRP before flashing should look like:
    Wipe data / factory reset
    wipe cache
    wipe dalvik cache
    wipe system
    Thanked by:
    I know it can't be backed up to Google because sometimes it IS wiped and I have to re enter the info. I just can't figure out why sometimes yes and sometimes no.
    Thanks for confirming that my process of wiping is at least the correct one.
    :-D
  5. #5
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    SENSE5
    Quote Originally Posted by 2defmouze View Post
    wipe cache
    wipe dalvik cache
    wipe system
    This. WiFi stuff is backed up by Google. Some light settings are stock, others are probably backed up on your SDcard if you have Light Flow/something like that.
  6. #6
    Jeff43's Avatar
    Posts
    ROM
    given up keeping track
    I have a downloaded wallpaper that even survived a resent factory reset. Go figure.
    The wallpaper was downloaded on the "SD card", but recently prior to flashing a new ROM, I did a factory reset. I flashed the ROM, Gapps, Kernel, but not the wallpaper. But low and behold when it booted, there was my wallpaper. Strange.
    Could that wallpaper somehow attached itself to a part of the system that is not touched, even with a factory reset?
    Factory reset and new Rom flashing doesn't affect anything on the SD card. That's why your downloaded wallpaper made it. i don't get how wifi settings and ROM preferences are saving. Liquid has a settings folder on the SD card so i get how that would possibly come back but i flashed a brand new ROM which i had never used before and it seemed to remember my notification color (i don't use Light flow). And if wifi password is stored on google servers, why doesn't it remember it EVERY time i flash a new rom. I'd estimate it remembers about 50% of the time. wierd.
    Thanked by:
    Jeff43
  1. no hspa+ /4g, but how does it work on hspa+
    By I am Fake Jesus in forum T-Mobile Nexus S
    Last Post: 01-14-2011, 02:15 PM
  2. how does it do email?
    By spacecasespiff in forum Motorola Droid Pro
    Last Post: 11-30-2010, 08:39 AM
  3. How does it feel Vibrant users?
    By Smokexz in forum T-Mobile Vibrant
    Last Post: 10-22-2010, 08:05 AM
  4. Unrevoked 3.21 Simple root is out how does it work?
    By clavodulce16 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-20-2010, 09:03 AM
  5. Evo in Pants Pocket - How Does It Fit?
    By sweat in forum HTC EVO 4G
    Last Post: 07-13-2010, 01:25 PM
