Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By 2defmouze
    Default ROM Manager premium help
    I have tried multiple ways to root etc and now have a question about rom manager premium
    I installed CWM without problems.
    When I click on make a backup it reboots my system. When it reboots the image of an android on its side with a hazard red triangle is present. I pulled the battery and it boots up fine.
    Any suggestions? I did make one directly by booting into recovery but it would be nice if this worked also.
    How many files should be in a Nandroid backup also?
    Thanks.
  2. #2
    2defmouze's Avatar
    Posts
    Global Posts
    5,846 Global Posts
    ROM
    AOKP
    Default Re: ROM Manager premium help
    Quote Originally Posted by amydaveg View Post
    Thanks.
    You haven't flashed your custom recovery permanently. If you don't want to, then before hitting anything else in ROM Manager you have to tap "Flash recovery" every time. Alternatively, using a file explorer with root permissions (such as root explorer) navigate to the /system folder and delete the file named recovery-from-boot.p
    Then next time you flash a recovery it will stick.
    dmmarck likes this.
    If it did not flash perminantly then why can I still boot into it manually?
    Is it only temporary if I use Rom manager?
    I tried what you said and it worked.
    Thanks
  1. Rom manager premium
    By jbomb11 in forum Motorola Droid X
    Last Post: 01-13-2011, 12:14 AM
  2. Rom Manager Premium not showing up in my paid apps list
    By Hitch_Itch in forum Verizon Droid Incredible
    Last Post: 12-15-2010, 06:14 PM
  3. Rom Manager Premium Problems?
    By tpdtopcop in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 10-18-2010, 02:11 PM
  4. Rom Manager Issue! Help?!?!
    By D2VW14_20 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 09-21-2010, 10:32 PM
  5. Rom Manager Questions - Help!
    By tuxedojacob in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-03-2010, 12:56 AM
B
