Results 1 to 7 of 7
    thenameisnigel's Avatar
    Posts
    Global Posts
    1,331 Global Posts
    ROM
    ProjectPanda 1.5
    Exclamation [GUIDE]How to build Project Panda
    [BOX=Disclaimer]Please note that Project Panda is a customized version of CyanogenMod / Android Open Source Project (AOSP). Project Panda is NOT supported nor endorsed by Cyanogenmod.
    [/BOX]
    How to build ProjectPanda for your Samsung Galaxy Nexus (Toro) ?
    Attachment 45361
    Prepare the Build Environment
    Install the Android SDK OR find your favorite adb.zip.
    [BOX=Installing required packages (Ubuntu 10.04 - 11.10)]sudo apt-get install git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev libc6-dev lib32ncurses5-dev ia32-libs x11proto-core-dev libx11-dev lib32readline5-dev lib32z-dev libgl1-mesa-dev g++-multilib mingw32 tofrodos python-markdown libxml2-utils xsltproc[/BOX]
    [BOX=On Ubuntu 10.10]sudo ln -s /usr/lib32/mesa/libGL.so.1 /usr/lib32/mesa/libGL.so
    [/BOX]
    [BOX=On Ubuntu 11.10]sudo apt-get install libx11-dev:i386
    [/BOX]
    [BOX=Installing required packages (Ubuntu 12.04)]sudo apt-get install git-core gnupg flex bison gperf build-essential zip curl libc6-dev libncurses5-dev:i386 x11proto-core-dev libx11-dev:i386 libreadline6-dev:i386 libgl1-mesa-glx:i386 libgl1-mesa-dev g++-multilib mingw32 openjdk-6-jdk tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386
    [/BOX]
    [BOX=Create the Directories for the Build Environment]mkdir -p ~/bin
    mkdir -p ~/android/system[/BOX]
    [BOX=Sync the Repo]Enter the following to download make the repo binary executable:
    curl > ~/bin/repo
    chmod a+x ~/bin/repo[/BOX]
    NOTE: A reboot of the computer may be necessary for the above changes to be recognized.
    [BOX=Initialize and Sync the Repo]cd ~/android/system/repo init -u git://github.com/ProjectPanda/android.git -b ics
    repo sync -j4[/BOX]
    [BOX=Sync Relevant Repositories]By default, The Panda Project 2.0 only syncs the core android repositories and none of the device or kernel trees to save both bandwidth and time. Run the following command to sync the necessary components for the device:
    . build/envsetup.sh && breakfast toro
    [/BOX]
    [BOX=Copy Proprietary Files]NOTE: This only needs to be run once. This step requires possession of the Toro with a working copy of CyanogenMod 9 installed and ADB working on the computer. This script will copy the proprietary files from the device.
    Connect the device to the computer and run the following commands:
    cd ~/android/system/device/samsung/toro/./extract-files.sh[/BOX]
    [BOX=Download Prebuilts]Downloaded Prebuilts are needed by the build:
    ~/android/system/vendor/cm/get-prebuilts[/BOX]
    Building Project Panda
    [BOX=Check for Updates]First, check for updates in the source:
    cd ~/android/system/repo sync[/BOX]
    [BOX=Configure Build & Compile]Now, the environment must be configured for the build process and then begin compilation for the Toro.
    . build/envsetup.sh && brunch toro[/BOX]
    [BOX=Pickup your Build!]
    1. Copy the .zip file from ~/android/system/out/target/product/toro/cm-9-XXXXX-UNOFFICIAL-toro.zip to the root of the SD card.
    2. Optional: Download Google Apps for CyanogenMod and place it on the root of the SD card.
    3. Flash both of these .zip files from recovery.
    [/BOX]
    Official Developer of Project Open Cannibal! (TeamHydro).
    Want to contribute to Project Panda? Click HERE.
    Want to view my personal GitHub? Click HERE.
  2. #2
    Default Re: [GUIDE]How to build Project Panda
    It would be great if we could get a little more detail as to what Project Panda is/does. Maybe a little sales pitch? I get that is a customized version of CM, but what about it is better or different...more customizations, new features, new tools???
    Semper Fi
    I love my LG Nexus 4!
  3. #3
    +1
    Posts
    Global Posts
    1,331 Global Posts
    ROM
    ProjectPanda 1.5
    Quote Originally Posted by greydarrah View Post
    It's mostly to give the unsupported devices, access to CyanogenMod features, but I am working on some kernel code changes. I'm not an engineer, but I'm good with a little coding. . .
    Sent from my Epic 4G Touch using Tapatalk 2
  5. #5
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    SKAnkCM10/Milestone6
    Deleted
    Posts
    Global Posts
    1,331 Global Posts
    ROM
    ProjectPanda 1.5
    Quote Originally Posted by JkdJedi View Post
    Deleted
  7. #7
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    Quote Originally Posted by thenameisnigel View Post
    I'd like to see this reviewed on a video, Got YouTube?
  1. [HOW-TO] Build your own kernel package from source
    By Jerry Hildenbrand in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 05-04-2013, 01:49 AM
  2. How to build your own dock using the phone's box
    By ConceptVBS in forum T-Mobile Vibrant
    Last Post: 08-20-2010, 10:45 PM
  3. Video Guide: How to Root the Samsung Moment, Add WiFi tether, (hotspot), and themes.
    By IOWA in forum Samsung Moment Rooting, ROMs, and Hacks
    Last Post: 08-02-2010, 02:22 PM
  4. Replies: 5
    Last Post: 06-30-2010, 08:04 PM
  5. [Sticky?] Newb guide -- How to root, recovery, and ROMs [Windows]
    By t0ast3d in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-20-2010, 01:19 AM
