Results 1 to 4 of 4
    Xanth269's Avatar
    Posts
    Global Posts
    428 Global Posts
    ROM
    AOKP Build5
    Default HELP with TWRP
    HELP HEP HELP
    was in TWRP to check version as I see new version is out for the up coming 4.2 rom, well I hit the small square box in the middle and it started to verify filesystems and partition sizes... been like this for 10 minutes now... battery pull? or will is finish what it started?
    THANKS!
    EDIT- Never mind, battery pull and all is good.
    Is there an easier way to update the TWRP files other than the .img file way?
  2. #2
    2defmouze's Avatar
    Posts
    ROM
    AOKP
    Default Re: HELP with TWRP
    Quote Originally Posted by Xanth269 View Post
    Fastboot the updated .img, doesn't get much easier.... But if you're truly lazy then goomanager should be able to do it for you I believe.
  3. #3
    mr.wizard's Avatar
    Posts
    ROM
    CM10 nightly/CleanROM 2.4
    Quote Originally Posted by 2defmouze View Post
    +1 I used goomanager because I am lazy
  4. #4
    BaMaDuDe87's Avatar
    Posts
    Global Posts
    183 Global Posts
    ROM
    BB 7/19 build
    I actually just dl'ed TWRP today to check it out and when I hit the middle button it did the same thing. I just hit it again after a few min and it went back to the home screen.
    Nexus running .............
    Coming from a 2 1/2 year old BB Tour
    Thanked by:
  1. Fellow PSU users in here? help with email?
    By mdc5162 in forum Motorola Droid
    Last Post: 09-02-2010, 11:51 AM
  2. Help with pic folders on sd card
    By allisongogators in forum Motorola Droid
    Last Post: 11-14-2009, 11:18 PM
  3. Need Help With Eris Signal !!
    By m.j.h.#ac in forum HTC Droid Eris
    Last Post: 11-13-2009, 07:03 PM
  4. Need Help with Facebook App
    By olson0827#ac in forum Android Applications
    Last Post: 11-11-2009, 09:25 PM
  5. Need help with Blackberry calender/scheduler to Droid
    By buckeye#ac in forum General Help and How To
    Last Post: 11-09-2009, 04:01 PM
