Results 1 to 15 of 15
- 12-04-2012, 01:35 PM
Thread Author #1
I wiped everything on my NEXUS! please help
Hello All;
I was going to update today to the latest cyanogenmod toro 10.0 and I wiped everything including the SD card that doesn't exist. Of course the image was lost and I cant access the SD card to a least copy the file there and install from recovery mode.
Note: I can access Recovery Mode and of course Download mode
Any help will be greatly appreciated
Thanks - 12-04-2012, 01:44 PM #2
Re: I wiped everything on my NEXUS! please help
It may not be gone. Check to see if there is a 0 directory on your internal storage open it. There may be another 0 director and open that keep going till you find all your files
From my Galaxy Note 2 via Tapatalk - 12-04-2012, 01:49 PM
Thread Author #3
I can't access anything on the phone but the Bootloader and Download mode, it is quite frustrating. My computer wont recognize the phone ( I guess ) when connected to Odin it always fail the installation. And don't know where to even begin looking for the directories.
- 12-04-2012, 02:06 PM #4
You should be Able to get to recovery
From my Galaxy Note 2 via Tapatalk - 12-04-2012, 02:07 PM #5
- 12-04-2012, 02:14 PM #6
He doesn't actually know if he wiped it because he cannot access it. So catch22 lol
From my Galaxy Note 2 via Tapatalk - 12-04-2012, 02:24 PM
Thread Author #7
In the process of doing a clean install I wiped the dalkin, the data, factory reset and by mistake the sd card where my new rom was sitting, so I have nothing, I van access the recovery mode but or the download mode but my computer wont see the drive, Odin seems to communicate but wont flash the rom. always fails.
- 12-04-2012, 02:31 PM #8
Did it wipe the card when it wiped data. Because that's what I did and I thought everything was gone. But some how it created sub folders and buried my files. Did you look into wugs toolkit suggested above?
From my Galaxy Note 2 via Tapatalk - 12-04-2012, 02:32 PM
Thread Author #9
- 12-04-2012, 02:35 PM
Thread Author #10
- 12-04-2012, 02:37 PM #11
Good luck hope it works out
From my Galaxy Note 2 via Tapatalk - 12-04-2012, 02:51 PM #12
Good luck!
Sent from my Galaxy Nexus using Android Central Forums - 12-04-2012, 07:20 PM #13
I just had something similar happen to me just now. Your SD card can't be recognized, right? Downloading Wugs as well to see what can be done.
- 12-04-2012, 08:18 PM #14
I couldn't figure out the Wugs thing, but I followed the "Return to Stock" sticky guide and it got me out of the bootloop. Maybe try that.
- 12-13-2012, 12:54 PM #15
I had this EXACT problem when I was trying to flash a ROM my first time I did this.
Open up adb and type this in
/data/media is where the SD card is mounted in Android, this will allow you to push the image to the phone and be able to flash it without first restoring then attempting again.Code:adb push <Image location here> /data/media
Good luck!
Auto Answer on my S3.....Please help?
By mandajayinc in forum Sprint Galaxy S3Replies: 37Last Post: 04-18-2013, 07:35 PM -
i really want ics on my nexus s4g please help me sprint model!
By goofy420247 in forum IntroductionsReplies: 1Last Post: 01-16-2012, 11:19 PM -
Still unable to see device on my PC - Please HELP!
By ochness in forum Verizon FascinateReplies: 7Last Post: 04-01-2011, 10:02 AM -
What is going on with my gmail..please help
By bugler in forum Motorola Droid XReplies: 20Last Post: 10-27-2010, 07:15 AM -
Screen Locks to quick on HTC HERO... please help
By SUP3RSTAN in forum HTC HeroReplies: 2Last Post: 11-21-2009, 11:46 AM
Reply
