Downloaded the adb from android development site and extracted files but when I go to open application it appears and vanishes quickly. Any help on how to fix this.
Sent from Galaxy Nexus Soucerize 4.2.1
Printable View
what OS is your computer?Quote:
Originally Posted by kilarican [Only registered and activated users can see links. Click Here To Register...]
and what are you trying to do with ADB?
if you're just trying to do fastboot/adb commands, i suggest just downloading Paul O'Brien's superboot because it's very simple to get started. Let me know what you're trying to do tho and i'll see what we can do.
I had this problem with SDK Manager quickly vanishing, this solution worked for me: "Make sure your java\bin directory is in your path statement before the windows\system32 directory. The SDK Manager uses java and it was finding the one in the system32 folder. In a CMD window, you can run 'where java' Hope this helps" [Only registered and activated users can see links. Click Here To Register...] .
I don't know if this helps..
Try: Open the sdk folder, hold shift and right click the platform-tools folder and click "open command window here"
