Results 1 to 4 of 4
    Default Adb not working...
    Downloaded the adb from android development site and extracted files but when I go to open application it appears and vanishes quickly. Any help on how to fix this.
    Sent from Galaxy Nexus Soucerize 4.2.1
  2. #2
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    ROM
    KANG
    Default Re: Adb not working...
    Quote Originally Posted by kilarican View Post
    what OS is your computer?
    and what are you trying to do with ADB?
    if you're just trying to do fastboot/adb commands, i suggest just downloading Paul O'Brien's superboot because it's very simple to get started. Let me know what you're trying to do tho and i'll see what we can do.
    * INCREDIBLE * MECHA * TORO * GROUPER * GALAXY S3 *
    * [TORO RADIOS] * [NEXUS WALLS] * [GROUPER GUIDE] * [CHATTER] *
  3. #3
    I had this problem with SDK Manager quickly vanishing, this solution worked for me: "Make sure your java\bin directory is in your path statement before the windows\system32 directory. The SDK Manager uses java and it was finding the one in the system32 folder. In a CMD window, you can run 'where java' Hope this helps" .
    I don't know if this helps..
  4. #4
    BaMaDuDe87's Avatar
    Posts
    Global Posts
    192 Global Posts
    ROM
    BB 7/19 build
    Try: Open the sdk folder, hold shift and right click the platform-tools folder and click "open command window here"
    Nexus running .............
    Coming from a 2 1/2 year old BB Tour
  1. ADB Not Connecting/Working
    By jyemenai in forum Barnes & Noble Nook Color
    Last Post: 05-29-2011, 12:36 PM
  2. Wallpapers not working
    By Fatasaurus in forum Motorola Droid
    Last Post: 11-08-2009, 04:15 PM
  3. Internet Not Working - Help Please?
    By thezob101 in forum General Help and How To
    Last Post: 10-30-2009, 09:03 PM
  4. Got 1.6 update on Vodafone UK but not working :(
    By varunbhalla in forum T-Mobile myTouch 3G
    Last Post: 10-22-2009, 03:24 AM
  5. Locale and Astrid not working
    By emooney in forum HTC Hero
    Last Post: 10-20-2009, 10:24 AM
B
