- 12-19-2012, 07:06 AM
Thread Author #1
CM 10.1 Nightly Data Issue and /0/0/0/0 folder
So I updated from AOKP Build 5 to CM10.1 yesterday and my data connection just refuses to connect. After about 4 or 5 attempts and reflashing and full data wiping I gave up and went back to AOKP5. The only problem is now my directory structure is nested in a folder /0/0/0/0/0/sdcard ...... I'm guessing this has to do with the reflashing of 4.2.1 and profiles? Has anyone else had either issue or know how to fix them?
I clearly love the Nexus line......
Devices: Nexus 7 16, Nexus 7 32, Galaxy Nexus, Kindle Fire running CM9 - 12-19-2012, 09:05 AM #2
Re: CM 10.1 Nightly Data Issue and /0/0/0/0 folder
Oh man, there's a ton of info on this, but I'll help ya out. 1) You MUST upgrade to the latest CWM or TWRP (ftw) that have been updated for 4.2.x. 4.2 brought a new tablet feature that allows for muliple users (hence your extra /0s). You might not have noticed the change if you were on the proper recovery. 2) I've found on many 4.2.x builds you must either enable data and/or change the network to CMDA/LTE, reboot into recovery, fix permissions, and then reboot to profit. Annoying, but it is what it is.
- 12-19-2012, 07:17 PM #3
- 12-20-2012, 08:16 AM
Thread Author #4
Thanks! Seem to be all good now.
Devices: Nexus 7 16, Nexus 7 32, Galaxy Nexus, Kindle Fire running CM9 - 12-24-2012, 10:25 AM #5
CM 10 Nightlies Having Issue with System UI constantly restarting/crashing
By sethgoldstein in forum Google / Samsung Galaxy NexusReplies: 9Last Post: 12-04-2012, 12:21 PM -
CM 10 Call Volume Issues
By mrshickadance9 in forum Verizon Galaxy S3 Rooting, ROMs, and HacksReplies: 1Last Post: 12-02-2012, 09:13 PM -
HELP What is the Proper way to install cm 10 nightlies?
By xxGBlackx in forum HTC EVO 4G LTE Rooting, ROMs, and HacksReplies: 3Last Post: 11-06-2012, 02:37 AM -
CyanogenMod 10 Nightly & M Build Change Log and Bug List
By dano92580 in forum AT&T Galaxy S3 Rooting, ROMs, and HacksReplies: 1Last Post: 09-25-2012, 12:18 PM -
extra MMS text with every MMS? and data issue
By owenrg in forum AT&T ATRIXReplies: 2Last Post: 03-18-2011, 12:26 PM
Reply
