Results 1 to 3 of 3
- 12-30-2012, 08:31 PM
Thread Author #1
How do I use an OTG cable?
I bought a new OTG cable for my Nexus (I am using Euroskank's AOKP ROM). When I plug in the cable with a thumb drive attached I see a message recognizing the external USB drive in the notification area. When unplug it I see a similar notification telling me it's unplugged. However, when it's plugged in I can't figure out how to see what's on the thumb drive. I go into file manager and don't see it show up there at all. What's the trick to exploring the information on the thumb drive?
- 12-30-2012, 08:43 PM #2
- 12-31-2012, 10:25 PM #3
Re: How do I use an OTG cable?
I use Eurostanks CM10 so you may be little different. Since it is recoginizing the drive when you insert and pull it, I don't think you need stickmount. On my GN, when I plug in my drive, it tells me preparing USB Storage. My onboard storage is located at /root/sdcard or /root/storage/sdcard0. my usb storage is located at /root/usbdisk or /root/storage/usbdisk
goodluck
How do I use a Nexus 4 on an existing AT&T connection?
By Rishabh Singh in forum Google Nexus 4Replies: 3Last Post: 12-25-2012, 10:49 PM -
How do I use OTG cable to access SD Card?
By OldDogEyes in forum Google Nexus 7 TabletReplies: 4Last Post: 11-20-2012, 03:00 PM -
How do I add an accoutn to use Microsoft active sync
By rdefino in forum General Help and How ToReplies: 2Last Post: 10-06-2011, 08:13 PM -
Added an sd card. How do I use it?
By rosariorose9 in forum Verizon Droid IncredibleReplies: 5Last Post: 05-23-2010, 08:43 AM -
How do I use folders?
By macjazzy in forum Verizon Droid IncredibleReplies: 8Last Post: 05-08-2010, 10:24 AM
Reply
