Results 1 to 4 of 4
    Default 4.2 camera problem, please help !
    sup guys, okay i know there a thread for this already but it seemed to died out..
    i recently rooted my nexus with codename android 3.8.0 (4.1.2)
    toro.
    and i cant use my camera " unfortunately, gallery has stopped" pops up..
    okay well i downloaded the 4.2camera.zip file went in to recovery deleted cache and dvcache , uploaded the zip, i tried setting the premissions to rw-r-r i believe thats
    what its suppose to be set at. and i rebooted and still nothing.
    I also deleted the gallery2.apk file. because they say that it could conflict.
    the only thing i dont get how to do is to move the lib. files? ...
    help me out please ! i miss my camera !
    thanks.
  2. #2
    pdub73's Avatar
    Posts
    Global Posts
    179 Global Posts
    Default Re: 4.2 camera problem, please help !
    Well if you really want the 4.2 Camera, you should probably try flashing to one of the 4.2 roms...I'm using Mmuzzy's 4.2 ROM that I flashed using Wug Fresh's Nexus Root toolkit, makes it very easy...
  3. #3
    I think you're making things harder than they need to be. If I were in your position, I'd do just as pdub73 suggested. Perform a full wipe (data/cache/dalvik), flash a shiny new 4.2 ROM (I'm partial to AOKP myself), and enjoy all of the 4.2 core apps. I know there were plans for 4.2 and later builds of CNA, but I'm not sure what happened. All I can find is 4.1.1 as the latest, and I only see reference builds for the GSM GN and the SIII.
  4. #4
    cabiggs152's Avatar
    Posts
    ROM
    Vanilla Bean
    Quote Originally Posted by pdub73 View Post
    Very true!! I just got this phone and it was the easiest thing I've done rooting and flashing wise and the ROM runs like a champ!! I couldn't be happier.. You should do that my friend
  1. Camera problem, please help!!!
    By Betty Xie in forum HTC One X
    Last Post: 12-16-2012, 04:50 PM
  2. EVO Camera Problem (Please Help)
    By jrob214 in forum HTC EVO 4G
    Last Post: 03-13-2012, 04:39 PM
  3. USB Problems, PLEASE HELP!!!
    By rob989_69 in forum AT&T Captivate
    Last Post: 07-25-2010, 08:53 PM
  4. Wi-Fi Problems! Please Help!
    By Basis in forum Motorola Droid
    Last Post: 07-16-2010, 10:37 PM
  5. since upgrade major problems please help
    By naenaek22 in forum HTC Droid Eris
    Last Post: 05-23-2010, 03:56 PM
B
