Results 1 to 4 of 4
    Default Phone Won't Charge
    Okay so out of nowhere, my Galaxy Nexus won't charge. While powered off it shows that it is charging but when I actually power it on, it almost immediately powers off from lack of battery power. It's as if it hadn't charged at all when it was powered off. I have tried 3 different chargers and it's always the same result. Also sometimes when I power it on, the whole home screen is rotated sideways. I am running AOKP. Any ideas? Thanks.
  2. #2
    lynnneil's Avatar
    Posts
    Global Posts
    99 Global Posts
    Default Re: Phone Won't Charge
    Factory reset the device and check.
  3. #3
    ConTejas's Avatar
    Posts
    ROM
    Super Beans n Kernels
    Try pulling the battery and holding the power button for at least 10 seconds to release built up static electricity. This is the trick for phones that won't trun on or charge at all, but it's worth a try in your case.
  4. #4
    Clean flash your kernel. Check the pins in the battery compartment. Follow ConTejas's advice to release any static charge. Finally, follow lynnneil's advice and do a complete reset to stock on your phone. No need to unroot or lock, but fully reset the ROM and kernel. Try charging, and if it works I'd try re-downloading AOKP and your kernel, verifying the MD5's, and re-flashing.
    Represent yourself well; you never know what might happen. And try out the new Android Central app!
    Softbricking be damned.
  1. Phone Won't Charge in (my) car
    By gyroslice in forum Verizon Galaxy Nexus
    Last Post: 06-20-2012, 03:38 PM
  2. Phone won't charge?
    By Simply_Dreaming in forum Virgin Mobile Optimus V
    Last Post: 04-19-2012, 07:49 PM
  3. Rooted phone won't charge, turn on, etc. Help!
    By wkupike2000 in forum Verizon Galaxy Nexus Rooting, ROMs, and Hacks
    Last Post: 01-19-2012, 09:53 AM
  4. Updated, now phone won't charge
    By Smoqr in forum LG Optimus S
    Last Post: 10-03-2011, 06:35 AM
  5. help phone won't charge !!!!
    By chawheefitzy@gmail.com in forum LG Optimus S
    Last Post: 04-22-2011, 01:53 PM
