Like most Verizon customers, I got impatient waiting for VZW to push out Android 4.2, so I used Wug's Toolkit to unlock and root my previously unrooted VZW Galaxy Nexus. The unlock and root worked fine, I then installed CyanogenMod 10 and the Google Apps package, and that's where my problem is.
Cyanogen loaded fine, but I apparently used a bad/incompatible version of gapps, so what happens now when I fire up the phone is I get the Google logo with the unlock icon (so far so good), then I get the Cyanogenmod boot screen (so far so good again), but then after that I get a message saying "the process com.google.process.gapps has stopped", which I cannot get out of; I dismiss the message and it reappears, I dismiss it reappears, etc. The only way to stop this loop is to yoink the battery out. After I took the battery out, I started back up in recovery mode, cleared all data/cache (including the dalvik cache), and tried again - and got the same problem.
I believe Cyanogenmod is installed correctly, but that gapps isn't; if my troubleshooting is correct, I think what I need to do at this point is to load the right version of the gapps .zip file (which I have now) onto my phone and install it from there. That's my second problem, though - my computer(s) won't recognize my phone. I've tried my XP machine, I've tried my iMac, and neither of them will recognize my phone at this point, and I don't know why.
So at this point, I have a completely unusable phone about which I'm panicking a little bit, because I have no idea how to get it to a point where it's usable again. I am extremely new at unlocking/rooting and not particularly technical, so if you could explain things to me like I was five I would really appreciate it. Thanks all.
