- 03-08-2013, 02:53 PM
Thread Author #1
AOKP: Easy way to keep updated?
I am running AOKP Android 2.2.1 Build 3 and while I love the ROM it does get a bit tiring to have to connect my Nexus to my laptop, wipe and flash the device, and then restore everything from Titanium. This has to happen after every new build is released, which is every few weeks.
Even after restoring from Titanium I loose all personalization such as data usage tracking, maps preferences, bluetooth pairings and a bunch of other stuff has to be re-adjusted. I bought Nova Launcher Premium thinking this would leave all my customized widgets in-place on the desktop and it didn't help.
Is there a simpler way for me to update to the latest version of AOKP as seamless as a carrier over-the-air-update, without loosing all my data and personalized settings? - 03-08-2013, 02:57 PM #2
Re: AOKP: Easy way to keep updated?
Normally the rule of thumb is if you stick with the same ROM from the same developer you can do a dirty flash. Its simple, just flash the new ROM right over the old in your custom recovery or Goo Manager, etc. WITHOUT wiping data.
I would still continue to make a Nandroid Backup to cover yourself in case things don't go as planned.
I do this quite often and even though the developer always says do a CLEAN install, you can get away with the dirty flash 99% of the time if staying with the same ROM and just updating to the newest release.
NOTE: When updating from AOKP built off Android 4.1.x and lower to Android 4.2.x it is recommend that you do a clean install because there has been a major file system restructuring that needs to take place.
:: Getting Started with Android :: Forum Rules :: General Help and How To ::
» » » The All New Android Central App « « «
- 03-09-2013, 08:16 AM #3
When I flash a new nightly, I usually wipe cache, davlik, and system. No issues for a while now. I assume that aokp and cm 10 aren't that different where you'd need to do a full wipe between nightlies
Sent from my Nexus 7 using Tapatalk HDBB World Edition->Moto Droid->BB Tour->Moto RAZR->Samsung Galaxy Nexus->Google Nexus 7
Always remember to wipe your Davlik!!! - 03-09-2013, 10:04 AM #4
- 03-09-2013, 08:10 PM #5BB World Edition->Moto Droid->BB Tour->Moto RAZR->Samsung Galaxy Nexus->Google Nexus 7
Always remember to wipe your Davlik!!! - 03-11-2013, 07:46 AM
Thread Author #6
Thanks. I did not know about the GooManager app. I have installed it and upgraded to Rom Manager Premium. So now I can flash on the go and hopefully Goo Manager will keep me updated with the new AOKP releases.
I did a dirty flash to AOKP Build 5 but I did not wipe Davilk and Cache because in ROM Manager it only gives you the option to wipe BOTH Data and Cache, or Not. I didn't want to wipe my data. I wish it would give me the option to just wipe Davilk and Cache and leave data intact. - 03-15-2013, 12:08 PM #7
Easy way to find the IMEI?
By tjp888 in forum Google / HTC Nexus OneReplies: 6Last Post: 02-27-2013, 06:37 AM -
found easy way to get palm memos to android
By CaptainET in forum General Help and How ToReplies: 3Last Post: 07-20-2011, 09:39 PM -
Easy Way to Reboot??
By kdb9904 in forum Motorola Droid XReplies: 7Last Post: 07-21-2010, 06:13 PM -
Easy way to get ADB in recovery
By borgey401 in forum Incredible Rooting, ROMs, and HacksReplies: 30Last Post: 06-22-2010, 04:35 PM -
easy way to switch roms?
By Lurch81#AC in forum Motorola Droid Rooting, ROMs and HacksReplies: 3Last Post: 05-17-2010, 12:15 AM
Reply
