1. cabiggs152's Avatar
    IdK it this is in the right section but my phone won't charge while its on and running but if I turn it off it will charge very slowly. Any suggestions or people who also have had this problem, any help is greatly appreciated.
    Sent from my Galaxy Nexus using AC Forums mobile app
    06-12-2013 09:20 AM
  2. cwilson7873's Avatar
    My phone is a Samsung Galaxy Nexus and is having this issue as well. Just prior to this occuring my phone suddenly switched to a picture of the Android listing version and model number on the screen stating do not disconnect target downloading. I had left my phone like this for 3 hours at work before I finally got tired of the message and pulled the battery after that the phone would no longer charge. Is there a fix?
    03-18-2014 05:23 PM
  3. Xanth269's Avatar
    Are you stock? custom rom ( whos and what version os ICS, JB or KK ) ? custom kernel, some details to fill in the blanks.
    my best suggestion if custom rom, clean flash of rom and gapps. keep stock kernel for a couple of days and than switch if you use someone else's kernel.
    03-26-2014 06:05 AM
  1. Charging while phone is off? Turns on when plugging in?
    By MONDINGO in forum AT&T ATRIX HD
    Last Post: 09-26-2014, 03:14 PM
  2. Battery does not Charge While Phone is Off (One X+)
    By BuddhistGirafe in forum HTC One X
    Last Post: 01-24-2013, 09:51 AM
  3. Battery will not charge while phone is plugged in
    By cyanozen in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 12-29-2012, 09:29 PM
  4. Charge when phone is on
    By ansa82 in forum Verizon LG Intuition
    Last Post: 10-08-2012, 06:56 AM
  5. Triumph Battery won't charge when the phone is on
    By cktp4400 in forum Motorola Triumph on Virgin Mobile
    Last Post: 08-29-2012, 10:48 PM
