Better Battery Life than Expected?
Zendroid1
Trusted Member
Aug 22, 2011
2,087
6
Is there a device out there that you can charge *just the battery? and not the whole phone with battery installed?
This would be handy.
DolfanCole
1,189
105
I know Samsung had a separate battery charger for their Galaxy S phones (specifically the Fascinate). Maybe there will be one for the Nexus as well.
mjforte
670
69
Here's my Bionic with pretty much the same exact usage and I was browsing a lot. Fares about the same. Standard battery btw.
mjforte
670
69
Looks like you have a cell standby bug there. Don't think it should be that high.
It seems to be some software bug on the Bionic. Seems to be fixed on newer leaked versions of OTA updates though. I've found that the high reporting of cell standby and phone idle actually have no bad effects on battery, but it's just reported incorrectly.
Cy3berOdyssey
