Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By edoublediz
    Default Smart Actions for Nexus?
    I'm still holding out for the G-Nex, but some things about the RAZR review catch my interest. Mostly is the "Smart Actions" function that will change phone states based on location and such.
    Does anyone have a recommendation for a Marketplace app that will give me this functionality on the G-Nex?
  2. #2
    botero's Avatar
    Posts
    Global Posts
    66 Global Posts
    ROM
    OMFGB Nighlies
    Default Re: Smart Actions for Nexus?
    Tasker does this. It won't control your LTE radio though as far as I know.
  3. #3
    Hilbe's Avatar
    Posts
    Global Posts
    106 Global Posts
    I use Locale.
  4. #4
    BBBay's Avatar
    Posts
    Global Posts
    60 Global Posts
    Default
    Quote Originally Posted by ultimate_ed View Post
    I'm trying to find out if my bionic does this or if I should buy locale from appbrain. Any advice?
    Sent from my DROID BIONIC using Tapatalk
  5. #5
    Snareman's Avatar
    Posts
    Global Posts
    750 Global Posts
    ROM
    Stock
    I've used both Tasker and Locale. Tasker is much more complex, has a pretty steep learning curve, but can do a lot more. Locale is much easier. I think I read that Locale also uses more battery because of the constant GPS searching, although don't quote me. It'd be cool of these things were built in to the phone though. Sort of like folders are in ICS.
  6. #6
    hyminameisderek's Avatar
    Posts
    ROM
    JellyBean! Franco Kernel
    I used to use Llama and was pretty satisfied. You'd search for towers in your location and then you could set what you want your phone to do based on your location. It was a bit finicky in some areas as my work and home were close so sometimes it would switch to full volume while I was at work.
  7. #7
    edoublediz's Avatar
    Banned
    Posts
    Global Posts
    1,147 Global Posts
    the smartest action this phone could perform is showing up on my doorstep!
    Mannysaurus likes this.
  8. #8
    I use impel and it works just fine for me. It's cheaper than most alternatives and does the job.
  9. #9
    StuartV's Avatar
    Allergic to Stupid
    Posts
    Global Posts
    585 Global Posts
    ROM
    Rezound Global v1.1
    Easy Profiles. You can control just about any function on your phone and the rules can be based on location, connecting to a certain WiFi AP, a certain Bluetooth device or whatever.
    I have mine setup so when it connects to the BT Handsfree in my truck, it automatically activates my "Car" profile (sets ringer Volume to Full, turns off WiFi, etc.). But it doesn't do all that if it connects to my in-ear BT headset. That's just as one example.
  10. #10
    StuartV's Avatar
    Allergic to Stupid
    Posts
    Global Posts
    585 Global Posts
    ROM
    Rezound Global v1.1
    Sorry. To be clear, that's on my Thunderbolt.
