Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By Cigar-Junkie
    bwillyM5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Question about Nexus charging voltage
    I know from the Google specs and pictures/videos that the Galaxy Nexus can be charged with either micro-USB or via the 3 pins on the right side of the device with the various docks seen today.
    However, does anybody know what the required charging amperage (current) will be. Can it be charged by a standard 5V - 0.5A USB power adapter or will it require a higher amperage like a tablet? I thought I remember reading something a couple of weeks ago that the GN was going to require more than the 0.5A that a USB 2.0 port can provide.
    Can someone with a Verizon or GSM Galaxy Nexus verify what the amperage of the included power adapter is and whether it will charge off a standard 0.5A USB port?
    Thanks!
  2. #2
    Nakrohtap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Question about Nexus charging voltage
    I was wondering the same thing earlier. I have been trying to find the OEM charger online somewhere to see the specs. All I know is with newer devices, you get the wrong voltage and you end up having problems from slow charge times to weird artifacts on the screen. The USB connected to the computer takes forever to charge my OG.
  3. #3
    Mr. Poppalopolis's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Android Revolution Hd
    I think most phones in the past few years use 1A wall chargers. Almost no smartphone will charge quickly through a USB port.
  4. #4
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    639 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    Voltage needs to be the same but what you are really talking about is amperage. The phone will take what ever it needs but the limiting factor is what you can give it. The more the merrier when it comes to amperage.
    Sent from my DROIDX using Tapatalk
    jlongjr27 likes this.
  5. #5
    jlongjr27's Avatar
    Posts
    Global Posts
    125 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Cigar_Junkie View Post
    Yep, what he said.
    It's interesting how many people are confused by this.
    Some newer motherboards and docking stations come with a USB port or 2 that will charge USB devices faster.
  6. #6
    thescreensavers's Avatar
    Posts
    Global Posts
    258 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Some phones will flat out not charge if the amperage is too low. 500ma is a good minimum if you are looking for a car charger. It the Gnex wall charger will probably be 800ma to 1amp
  7. #7
    Nakrohtap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I looked everywhere online this morning to find the mA rating for the GN wall charger and found nothing. The charger for my OG is rated at 850 mA. Does anyone know what the correct rating for the GN is?
  8. #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    My guess would be its 1A.
  9. #9
    captaincaveman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Will an OG Droid car or wall charger plug into and charge the Nexus? Are the charging ports the same style?
    Sent from mind using the power of prayer
  10. #10
    Deltaechoe's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Rooted odexed 4.0.2
    As the other posters have stated, one amp is pretty standard, all you need is a standard AC to USB adapter that outputs 1A and you will be golden. Also, I'm pretty sure it will charge of a USB port, just not particularily quickly just like every other smartphone. I don't see OEMs changing this anytime soon considering it is so integrated in the current smartphone market that a number of people would probably balk at the prospect of not being able to charge their phone through their pc
  11. #11
    DBVille's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Deltaechoe View Post
    What Deltaechoe and a bunch of others have said. USB spec is like 0.5A, which can barely power my original Droid. If I am using it for navigation or music, with the screen on, it won't charge it. You will need a 1 amp charge rate. Many car chargers now are 1 amp, even the cheap ones. I have had my OG Droid connected to a charger, and showing charging, but battery level decreased because the amount the phone was drawing. With the high rate USB chargers, it will always charge, and pretty quickly.
    I am assuming the Nexus charges through the USB port, but am not sure.
  12. #12
    Nakrohtap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by captaincaveman View Post
    Like I said, I have an OG Droid as well. My wall charger is 850 mA and I found out yesterday online that my Moto car charger is 950 mA. All connections work interchangeably. Just make sure your chargers are up to snuff. If you bought some cheap non-OEM charger for your car, you may want to upgrade that one.
    I was asking originally because I usually keep a second charger at work to keep my phone plugged in while streaming. I was just trying to figure out if what I had would suffice or if I needed to get a new second charger.
  13. #13
    Nakrohtap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by DBVille View Post
    I looked at a TON of wall chargers online yesterday. NONE of them stated the mA rating, even when I clicked on "more specs". Wouldn't manufacturers and retailers feel that this is an important piece of information to disclose when someone is determining which charger to purchase?
  14. #14
    mastawyrm's Avatar
    Posts
    Global Posts
    39 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Back during the announcement I was hoping they would say it's compatible with USB 3.0 even if just for the extra power available.
  15. #15
    DBVille's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Nakrohtap View Post
    Yeah, unfortunately they don't provide much. Look for photos of the label on the device, like this one which shows 0.7A (700 mA), or this one, which shows 750 mA. Note that if they are too cheap they may be knock offs, which may or may not be able to match the labels.
  16. #16
    Nakrohtap's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    True. I read a lot of the reviews before selecting a retailer.
  17. #17
    tumpin's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just check my GN charger and its 1amp
  18. #18
    tumpin's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your right, they should list it. I just bought a charger from Amazon that said it was for all Galaxy phones including Nexus but its arrived and its 0.7A. Its not really a problem, it will still work fine but its still not the same as the original charger and thats what I was looking for. If they listed to amps I could have got the right charger. Anyway have a nice day!
  19. #19
    tumpin's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oops I thought this was this year, haha
  20. #20
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    If you have a rom with a kernel that enables fast charging it's a real joy .
  21. #21
    mscroggi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The OEM Nexus 7 charger is 2 amps. Like the others have stated, 1A should be a minimum for decent charging times.
