Results 1 to 11 of 11
- 12-15-2011, 09:43 AM
Thread Author #1
The battery upon purchasing...
Should I let it drain all the way to 0, then charge it? Or should I charge it now while it's still running? I can't remember what you gents told me to do, but I'm def psyched to own this phone.
Any other recommendations? - 12-15-2011, 10:08 AM #2
Re: The battery upon purchasing...
I don't think it matters with lithium ion batteries.
- 12-15-2011, 10:10 AM #3
- 12-15-2011, 10:11 AM #4
With lithium ion batteries you want to try to avoid letting them hit 0. They have a finite number of charge cycles from both dead and partial. Dead to full is a much smaller # than partial to full.
- 12-15-2011, 10:12 AM
Thread Author #5
Cool, thanks for the tips everyone, much appreciated.
- 12-15-2011, 10:12 AM #6
I work for Interstate All Battery Center & it does not matter with Lithium Ion batteries. They have no memory effect. So you're good to go!
:o BlackBerry 8100 --> BlackBerry 8330 --> Blackberry 9630 --> HTC Incredible ---> GALAXY NEXUS - 12-15-2011, 10:13 AM #7
I thought I read that you should let it run all the way down, charge it up and run it all the way down again so that Android can calibrate itself to get an accurate reading on battery life. It doesn't actually make the battery better or worse, it just calibrates the phone.
- 12-15-2011, 10:14 AM #8
- 12-15-2011, 10:18 AM #9
Not sure about cell phone batteries but with laptop batteries there is a finite number of charges, at least with my old dell. I have never ran into this problem with cell phone batteries.
One day my laptop wouldn't charge anymore eventhough it had 80% charge remaining and it would run the laptop on the battery until it died and it wouldn't charge anymore. I think that's because there is a chip in laptop batteries that monitor the battery life much more closely. I could be wrong though. - 12-15-2011, 10:21 AM #10
- 12-15-2011, 10:31 AM #11
I just charge it up and go. I've never concerned myself with the battery and never had one quit lasting as long etc. Of course I have a tendency to swap phones out ~14 months or so apart so maybe I'm not reaching out into the life span where it would be seen. So I would say if you plan to keep your phone 2 years or less I wouldn't worry much about it except not letting it totally die too often.
I've watched my battery on the Incredible since release and I don't have one drop longer or shorter since day one. It's died completely a few times and came on and off charger a ton depending on the situation and how much power I would need when I was gone from home. The only thing that changes by battery rate was undervolting / overvolting / overclocking it and swapping roms.The Storm has cleared to an Incredible day! I ate an IceCream Sandwhich. Still needed JellyBeans. ;-)NEXUS!!!!!!
Reply
